ASP underdrive pulley?, meziere?
Old 04-11-2009, 01:26 PM
Flielow's Avatar
Default ASP underdrive pulley?, meziere?
I dont like this new "search" function much and haven't been able to find the info I need.
This is going to be on my stock bottom end (for now) w/ a 231/237 .598 (112 or 110), Mamo ported FAST90/90, kooks lt's, true duals 2.5'' w, sweet thunder chambered muffers (LOUD), and all the suspension goodies
I have a D1sc (4.50 blower pulley) 8 rib set up, and have been trying to get all my parts ready for it to b installed, so far this what I have
1. Walbro pump
2. fuel, boost, gauges and AEM Wideband
3. Will be getting siemens 60 lbs
4. and I have a meziere water pump sitting around
So my question is can I use the ASP underdive pulley that's on the car now?, or do I need to buy an ATI Balancer (Dampner) or a stock pulley?
Will using the meziere help to keep my temps down?
Thanks in advance for the info, I've been searching and called Procharger directly and still couldnt find a straight answer
Old 04-11-2009, 10:14 PM
stevied916's Avatar
The ATI damper is the only one that accepts the procharger pulley. I think SDCE might make a 8 rib that fits on the stock pulley though; you can try calling them
Old 04-12-2009, 06:58 AM
EPP
EPP's Avatar
http://www.exoticperformanceplus.com...html?item=1542
This is the balancer we typically use with the ATI ProCharger LS1 F Body 8 rib kit.
The Meziere water pump is a great pump to use, and may help in stop and go driving. Bob
Quick Reply: ASP underdrive pulley?, meziere?
