Power limits for Honda rod journal size?
Old 04-18-2009, 02:47 PM
brobards's Avatar
Default Power limits for Honda rod journal size?
I have an eye on a nice billet crank, but it is using a honda rod journal size (1.85"). Will a crank that has a smaller rod journal like this be an issue for higher horsepower (1200+)? Would this crank best fit using aluminum rods?
Old 04-18-2009, 03:03 PM
01ramair500hp's Avatar
are you on the right board ?
Old 04-18-2009, 03:28 PM
Floader's Avatar
good question, not that i know the answer, but on the oval cars we use the honda rod to make the rotating assembly lighter. maybe it cuts down on friction due to the smaller bearing also? I know they hold together in the race cars, we turn our motors 8000+, but they only make 600fwhp at most.... I would like to know the power limits also.
Old 04-18-2009, 10:50 PM
T/AWS6969's Avatar
I would say it should handle some decent horsepower. BEWARE if you add the coffee can exhaust tip that should double the net power it and blow it all apart! LOL! jkn Someone had to do it bro!!!
Old 04-18-2009, 11:55 PM
crashly's Avatar
pro stock make 1350 + on 1.85 journals
Old 04-19-2009, 05:46 AM
Tom@SpeedInc's Avatar
FWIW Callies Magnum XL crankshafts are Honda Journal or 1.888" unless specified.
Its not something I would use for heavy boost/Nitrous. 2.000" Journal i'd feel confident with about any power adder when using the right parts.
Crankshaft is fine, the piston/rod combination can be trouble some, I have methods of ordering parts to solve alot of these headaches.
Old 04-19-2009, 10:55 AM
LS1Tech Sponsor
hellbents10's Avatar
We use them a lot in our SBC builds for the roundy round guys up to and a bit above 700hp. I would use a 2.100 rod in a big hp engine though.
Old 05-12-2010, 04:19 AM
Hans Grüber's Avatar
Does anyone know the history behind the Honda rod journals in GM V8's? I've always been curious about this. Did someone back in the day figure out that Honda connecting rods worked if you simply cut the crank down?
Old 05-12-2010, 06:54 AM
crf538's Avatar
i know the nascar guys have been running them for a while
Old 05-12-2010, 08:03 AM
oneoverwrx's Avatar
Forgive me, but why would a honda journal size restrict power. Bunch of 12-1300hp hondas running around now a days, on stock size bearings. LOL
Old 05-12-2010, 08:22 AM
jamnut's Avatar
Lots of confusing information here. Small journal sizes are used for lighter cranks & less bearing friction to help get ever last bit of power out of a max effort motor, or a motor that is restricted due to class or something like that. They are not Honda Journals, just Honda sized. It's more of a circle track, restrictor plate, CI restriction trick to get these motors spinning higher due to less friction & weight.
Quick Reply: Power limits for Honda rod journal size?
