trying to transition to boost
OK so i built this car with nitrous in mind, and i love the juice, its addicting, but im debating on going the boost route, after much searching I have these Questions:
first (firebird 347 ls1, 10.4 CR with .04 gasket, 3600 stall built tranny, 3.73 rearend 10 bolt)
car made 414 rwhp Na, and decent 500's on a small shot
A.my concerns, If i can get the CR down to 10-1 what realistic boost numbers can I run with a little P1 blower?
B.my cam is a 232 234 598/601 112, how bad does this need to be changed
C.I have 42.5 lb injectors, and am seeing 73ish% ICD
D. im trying to get into the low-mid 500 hp range, close to my n20 numbers
That's what she said...
You might be able to leave the CR and put on a meth kit. Spraying in a bunch of meth might save you some dough on a fuel system too.
You could buy the fail safe that Snow sells and wire it into a timing controller to yank a bunch of timing and light up a warning should the meth fail.
Dumb Ass Vette Moderator
B) Not the most optimal, but the cam should make some good power.
C) You will be pushing 42# injectors, so get some bigger ones.
D) You should be able to break the 500 rwhp mark with a P1SC and easily break the 500 rwhp mark with a D1SC.
