No Bottom End?
Old 04-20-2009, 11:43 AM
onefastbunny's Avatar
Default No Bottom End?
i finally got my car to the track after the turbo install and my 60 foot times are much worse than they were before the turbo the car doesnt feel like its spinning just felt like it had no bottom end pull im currently running the stock converter does this sound about normal? im thinking about a stall converter but was looking for some input before i drop that kind of money
Old 04-20-2009, 11:51 AM
code4's Avatar
Not enough info, were you building any boost at the launch?
Old 04-20-2009, 11:58 AM
sorry no i wasnt building boost im guessing because i couldnt raise the rpm's enough
Old 04-20-2009, 12:06 PM
code4's Avatar
You def need a little bit of stall speed & a 2 step would get you some boost. Rear mounts need a little help in that area. I would read some of zombie's posts on the subject.
Old 04-20-2009, 01:54 PM
thanks for the help
any recommendations as to a stall speed?
Old 04-20-2009, 02:20 PM
Dumb Ass Vette Moderator
ls1290's Avatar
On autos, the size of the stall is dependent on the cam size. What size cam do you have?
Old 04-20-2009, 02:24 PM
LS1Tech Sponsor
hellbents10's Avatar
Tune can play a big factor especially with a MAF. If it is only running 17* of timing and a 11.5:1 AFR before it starts making boost it will be a sled till the charger lights up.
Old 04-20-2009, 04:31 PM
It currently Is just the stock cam
Honestly im not sure about the details of the tune i know it needs more fine tuning it was only street tuned and only run on the dyno two pulls just to see where i was at power wise
Quick Reply: No Bottom End?
