What timing are running over 15psi and what octane fuel are you using?
Old 04-20-2009, 03:50 PM
Zombie's Avatar
Default What timing are running over 15psi and what octane fuel are you using?
Post away
I'm at 17 peak torque up to 23 by 7000 on 100 octane and 16psi. It's on the edge of detonating though. I'm not using any meth or alcohol. I'm seeing a 40-50 degree IAT temp rise on a full pass.
Old 04-20-2009, 04:23 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
Old 04-20-2009, 04:27 PM
veee8's Avatar
24* with E85, less then 20* rise from beginning to end.
Old 04-20-2009, 04:29 PM
lt170chevelle's Avatar
im tuning in for this one..
Old 04-20-2009, 04:41 PM
cablebandit's Avatar
15...max for me...c16
Old 04-20-2009, 06:37 PM
98Camarod's Avatar
Originally Posted by Zombie
Post away
Thats a big jump in IAT's, no?
Old 04-20-2009, 09:07 PM
Zombie's Avatar
Yes. I talked to Jose and he thought it was really high as well. Going to be doing some logging to try and figure out the restriction.
Old 04-21-2009, 06:29 AM
Fireball's Avatar
at that low of timing...why bother with C16
I run 20+ deg
C16/Q16
Old 04-21-2009, 06:40 AM
98Camarod's Avatar
I run 20+ deg
C16/Q16
Says its for safety. What is c16 anyways and q16 for that matter?
Old 04-21-2009, 06:43 AM
Fireball's Avatar
VP racing fuel blends
C16: http://www.vpracingfuels.com/spec_detail.asp?id=11
Q16: http://www.vpracingfuels.com/spec/Te...letin--Q16.doc
Old 04-21-2009, 07:37 AM
'Trust''s Avatar
18*, 93+Methanol. It could probably take a good few more degrees, but I'm leaving it.
Old 04-21-2009, 03:15 PM
I am at 20 with 93 pump gas and no meth with 10lbs intercooled at 9.5.1 comp. I would think 18 degrees and some race gas that should be about right with 15lbs..especially if its a low comp motor.just my uneducated guess.
Old 04-21-2009, 03:26 PM
I run 20+ deg
C16/Q16
i dont want to lift any heads if it went to 20+ psi instead of my normal 12. Also gives me a little safety if something gets screwed up and my tune is off. Already seen 13.3 a/f at the 1/8 once with no damage with c16. I am not racing...just test and tune and its worth it for the extra insurance. I am on the porch with the little dogs...let you big dogs run the big numbers.
Old 04-21-2009, 07:57 PM
Coal Mining Director
onfire's Avatar
Need to look at Timing, Octane and IAT's (plus the combo)......AtoW icepacked can run more timing per psi then AtoA.
Old 04-21-2009, 08:18 PM
crf538's Avatar
seems like comp ratio should be included in this thread as well
Old 04-22-2009, 07:27 AM
true .....mine is 10.4:1
Old 04-22-2009, 11:25 AM
camarokid94's Avatar
not to hijack but i love your vid great car man is it still streetable? do you have a build thread or anything
Old 04-22-2009, 11:42 AM
'Trust''s Avatar
How do you like your 4L80E? I've been thinking about switching to one, my race weight is similar to yours (3966) so I think I need a more rugged trans. What kind of power are you making? What were your 60's?
Old 04-22-2009, 06:20 PM
code4's Avatar
13 degrees with 91 octane for street use. I bump it to 18 with race gas at the track sometimes. 10:1 to 1 compression ratio.
Old 04-22-2009, 07:19 PM
7 Second Club
NicD's Avatar
Some of you guys get away with a decent amount of timing!
I'm at 15 deg on 11 psi/91 oct and at 16 psi/91-109 mix. My timing basically remains the constant at WOT with either boost level and I just run better gas. Also I'm at 8.5:1 compression.
Quick Reply: What timing are running over 15psi and what octane fuel are you using?
