So here it is... Vid inside...
Old 04-22-2009, 01:31 PM
2002RamAir's Avatar
Default So here it is... Vid inside...
So after about two months of waiting and two more months of building... Here is my kentucky turbo t78 kit.. The car has a baby cam and some support mods for the turbo.. Here is the vid http://www.youtube.com/watch?v=Uqbp-fWbzT8 The dyno number came about about 100+ hp short... stupid clutch is not holding causeing the motor to lose load at about 3000rpm let me know what you all think!!!!!
Old 04-22-2009, 01:38 PM
HUNTER02SS's Avatar
Sounded good. Get a good clutch and turn the boost up!
Old 04-22-2009, 06:20 PM
Turbo6Speed's Avatar
Sounds good! Is that the regular T78 or the TC76? How much are you expecting when you turn the boost up and get a clutch?
Old 04-22-2009, 06:48 PM
98Camarod's Avatar
I seen your car up there when you first dropped it off. Think looked clean. I didn't get to hear it he was messing with your alternator. Sounded good, fix that clutch!
Old 04-23-2009, 11:31 AM
2002RamAir's Avatar
Thanks man.. Yeah just got the alt figured out ended up being a head rubbing issue. The guys at speedinc and machinehead are amazing.. Took care of everything for me!!! Anyways, Got a monster 4 on its way with a tick master.. should take care of that!!!
Old 04-23-2009, 08:56 PM
trans2000am's Avatar
sounds nice what exhaust you running?or is it just dumped after down pipe?
Old 04-25-2009, 01:04 PM
2002RamAir's Avatar
That was just dumped after the down pipe. I had the exhaust finished up and I have a Corsa catback. Will have another video after we put in the new clutch.
Old 04-25-2009, 01:36 PM
Sluggish's Avatar
How much power and at what psi, I couldn't read **** in the video. Josh's kit killed my clutch also, I had to upgrade to a twin.
Old 04-27-2009, 02:24 PM
2002RamAir's Avatar
It is making 383hp right now.. hits about 5psi at 3200rpm then a steady drop down to about 3psi or so... the motor is loseing load at about 3k rpm. Im sure the stock clutch and my leaky dripping running rear seal is not helping at all...
Quick Reply: So here it is... Vid inside...
