procharger questions
Old 04-24-2009, 11:47 AM
dpinson's Avatar
Default procharger questions
ok guys i think i just about have all of my setup lined out
going with a forged 347,317 heads,d1sc at around 16lbs on 9.5 to1 compreesion,fmic and meth,looking to run pump gas
What about the stock ignition system though, how much can it handle?
Would the truck coils handle 700-800 at the wheels?
or do i need to get a good msd setup?
also what about the throttle body?will stock work or do i need to get a better unit?any suggestions?
Thanx,Daman
Old 04-24-2009, 01:06 PM
DanZ28's Avatar
Stock coils are fine, save your money on the MSD's.
Stock TB is probably fine as well, maybe have it ported..
Old 04-24-2009, 01:37 PM
conan's Avatar
What are you doing for your fuel system?
Old 04-24-2009, 03:45 PM
dpinson's Avatar
lonnies dual setup,with edelbrock rails and aeromotive boost ref. regulator,60lb. injectors
-8 on feed? do you think i need to go bigger?
Old 04-24-2009, 04:15 PM
11Second Club
Gauge's Avatar
-8AN feed will be fine.
Old 04-25-2009, 01:06 AM
conan's Avatar
You'll be happy with your lonnies dual set up too. I just put mine in about 2 weeks ago and final have fuel pressure all the way to 6,800rpms.
Quick Reply: procharger questions
