Need to buy the APS Banjo bolt and fitting. ASAP
Well long story short. A shop lost all my turbo fittings and had to order $400 dollars worth of fitting from APS. But now there not making the Banjo bolt anymore and I can't find one anywhere. They sent me the specs to have one made, but gzzz come on now...
So these are the part numbers I need. 1 of each.. Thanks guys
000-071-200
000-949-200
000-071-200
000-949-200
Ok I can find the first part all day long but the second picture. is a different story.. Its a 14mm x 9/16 JIC size... All I can find are -4an size fittings.???
Any help..
Any help..
Umm... I already told you. There are charts on this and this page showing what AN (or "dash" as it's commonly referred to) size to use with 9/16" JIC. If XRP rubs you the wrong way or something try AP Tuning or your local hose/hydraulic supplier instead. All you really need to do is make sure the water lines supplied by APS have a 37° flare. I bet they do.
