How to figure out how much turbo you need
1st find cfm unboosted (CFMU):
(C.I.D/1728) X (maxRPM/2)= CFMU
2nd find Pressure Ratio (Pr):
(14.7+Desired boost) / 14.7=Pr
3rd find CFM boosted (CFMB):
CFMU X Pr= CFMB
4th convert CFMB to LB/min:
CFMB X .07= (required LB/min)
5th look at the comp map and use your required LB/min and Pr to place yourself on the map, trying to be in the lower right hand corner of the efficiency islands.
I hope this helps,
Rob@modularturbo
CFMU X Pr= CFMB
I hope this helps,
Rob@modularturbo
