Twin Turbo size suggestions for ZO6!!! (rear mount)
Old 04-28-2009, 08:12 AM
venom ws7's Avatar
Question Twin Turbo size suggestions for ZO6!!! (rear mount)
O.K I'm planning to go with a bigger engine now I still didnt turn the boost with the small old turbos but since I found a good deal on LS2 6.0 engine I thought about going bigger Too.
Best dyno run with old 347ci 8:5 compresstion MTI H/C STS Twin GT28
Made 557rwhp with only 9psi I was planning to boost it up but I maxed out the injectors.
Here is the new goal 750rwhp on PUMP GAS 13-14PSI Is that possible?????
402ci 8:5 or 9:0 compresstion Diamond Pistons, Callies Crank, blah blah blah
MTI 317 72cc Heads or If I can I will sell them and get AFR 225 or TFS 235
EPP Cam 236-240 595-608 115lsa If I'm not mistaken those are the specs.
LS6 Intake.
Stock TB.
Fuel system.
RPM Transmisstion
Exedy clutch and flywheel
Stock 3.42 Gears
and of course to help a little MT 305-35-18 on IFORGED Evolution
Now what I need is turbos suggestion but keep in mind this rear mount turbos
my old setup was a little laggy I know bigger CI Will help but still.
Where can I buy them??
Shoot away
Thanks in advance
Hussam
Old 04-28-2009, 08:45 PM
highpockets's Avatar
Any particular reason you are holding firm on a rear mount setup ?
Old 04-28-2009, 10:54 PM
to-fst-4u's Avatar
probably because that is what he already has, just wants to upgrade turbos.
Old 04-29-2009, 12:26 AM
ScorpionT's Avatar
The Precision 6062 or 6262 would be a good match. If you want less lag the rear mount setup definitely isnt helping.
Old 04-29-2009, 12:37 AM
sultan(ZR-1)KSA's Avatar
my choice will be
Garrett GT3582R (aka GT35R, aka GT35/40R)
http://www.atpturbo.com/Merchant2/me...egory_Code=GRT
Old 04-29-2009, 01:32 AM
chuntington101's Avatar
GT35s have been used but will lag a bit. GT30s with small enough housings might work better. cant you push the GT28s a little harder and see what they can do? they have made over 600rwhp on C6 APS kits.
drop me a PM and i can point you to a tuning company thats currently building a 1000++rwhp C6 that they are aming to get into the 8's using the STS kit. they should beable to point you in the right direction for you power goals!
Chris.
Quick Reply: Twin Turbo size suggestions for ZO6!!! (rear mount)
