Help!!! Planning on boosting LS1
What are the best products on the market for running boost? I had plans of first building a forged LS1 and getting the most RWHP i could get out of it and then add a turbo kit setup. But now im going to just go str8 for boost. So what components on the market are best for boosting the LS1. Im still going with forged components because it makes no since to me to just throw a turbo kit on it and break rod's and what not. What is the best turbo kit out on the market? What rod's, pistons, cam...basically what internals are ppl using that aren't failing on them and are actually worth it. Car is a 95 T/A M6with a 99 T/A m6'S driveline. I already have a Fast 92mm intake and tb. Any help will be appreciated. And please no negitive comments. Thanks
Also power goals are around 7xx to 9xx RWHP
Also staying stock cubed with it...kinda wanting to go after the stock cubed, full interior title
Take a look at this link.
http://www.exoticperformanceplus.com...php?service=83
We use the above combination on many builds, and we used the above build on this Corvette, shown here.
http://www.exoticperformanceplus.com...Car.php?car=54 Bob
well then for that kinda power ur looking at 20-30k easy. youll need a new rear end, trans, suspension, and a built motor. ull need a forged motor and if u want a 346 or 347 then id go with a st80 or bigger. its gonna be laggy but talk to the sponsors and try a search to better help you
