408 w/STS build pending Opinions welcome
Old 05-03-2009, 10:23 AM
OreoLt1's Avatar
Default 408 w/STS build pending Opinions welcome
Ive been searching and planning out my build for awhile and but of course have about 90 different directions to go. I would like to hear some of your guys opinions/reccomendations on specs and et.
Block of course is a 6.0 iron
sts kit with gt67 for now but will go to a probably gts76
will be somewhat of a DD but soon to be a garage queen/weekend car
looking for around 600-700 rwhp
M6
was thinking callies magnum crank
arp everything
callies rods
diamond pistions
dm racing engine girdle
cam?????
heads????
valvetrain????
Any input of reccomended experience will be highly appreciated!
Old 05-03-2009, 10:30 AM
Zombie's Avatar
Originally Posted by OreoLt1
Block of course is a 6.0 iron Good choice
sts kit with gt67 for now but will go to a probably gts76 Way too small for a 408, 80mm min
looking for around 600-700 rwhp Don't bother with a 408 for this power level, 346-370 works great
M6
was thinking callies magnum crank stock is good unless you are determined to spend money
arp everything
callies rods
diamond pistions
dm racing engine girdle Complete and utter waste of money for your build
cam????? z06 if you don't do a stroker
heads???? stock 317s work fine
valvetrain???? stock with good valvesprings
Those are my views, yours may differ. I like going: fast, reliably and cheap.
You going custom on your rear mount or STS? If custom I'd suggest running a quick spool valve like I do (takes some basic fab to get it installed).
Old 05-03-2009, 10:34 AM
1320's Avatar
but, but, but he said m6.........so you know he doesnt want it fast, reliable or cheap.
It will be fun though.
Old 05-03-2009, 10:36 AM
1fast bird's Avatar
I have a perfect turbo for a 408...
Old 05-03-2009, 12:03 PM
OreoLt1's Avatar
Ive read good things about the engine girdle but I was thinking it may e overkill for what im looking for.
Also recently read a thread tht a oe crank was holding on at around 1200-1500 so that was gonna be a possible second choice.
hmm havent read too much into quick spool valves... could you enlighten me any more Zombie?
Also I know they're out there but haven't found them yet, any spec./cheat sheets for ls1 and 6.0l oe parts and specs. I know i'll run into issues like crank reluctors and such.
Cheap is better but reliability is priority. Just have the block now but will begin looking for remaining components shortly like oil pan, valley covers, etc. Pretty much from scratch!
Old 05-03-2009, 12:40 PM
jonathan8751's Avatar
I have a 2006 gto with a 408 stroker, sts kit w/ tc76, afr heads, and 100% meth. My goals were similar to yours but grew before build was complete. I am looking for 900rwhp spinning the **** out of my turbo. I have also been wanting to use the quik spool valve.
Old 05-03-2009, 12:45 PM
BlkHwk's Avatar
I am running the Callies Magnum XL crank. Expensive but a badass crank IMO.
Old 05-03-2009, 01:09 PM
Zombie's Avatar
A tc76 will not get you close to 900rwhp on a 408, 700rwhp maybe. You will need to go to a 88mm turbo to get there.
Old 06-06-2009, 10:55 AM
CMR_ls1s's Avatar
Zombie, Could you show us some pics of your set-up with the quick spool valve.Its sounds like the way to go. Im planning a rear mount on the camaro and going with a 370 with a tc78(would a pt88 be to big or just about right with the quik-spool valve?)
Old 06-06-2009, 12:00 PM
jasonmurry69's Avatar
i was told NEVER to use the magnum xl crank only the magnuim for forced induction cars by several people.
Old 06-06-2009, 12:21 PM
1320's Avatar
Idont think a standard bearing 88 would work very well even with a quick spool valve. I tried an 88 on zombies car with no valve, and it was bad. A ball bearing turbo though......would probably be fine. My bb 101 would prob spool better then a standard bearing 88, or atleast comparable.
For big hp rearmounts, an sx 80 (87 i think) with a divided housing or something very similar is about as big as I can see being real nice. Ofcourse if your willing to spin your motor higher, spend the money on better heads, have a higher stall....then a bigger turbo would work.
Cost difference in the builds, id 1500+ more for heads, 400$ more for valve train stuff over a oem zo6 cam, and less drivability with the bigger stall. The stall could be offset with less weight but that too may result in less drivabilty depending on opinion.
An sx80 and 370 gets you to 10.0's or better anywhere in the country in a heavy *** loaded street car. So if high 9's are ok with you, dont bother with more.
Old 06-06-2009, 07:52 PM
CMR_ls1s's Avatar
Thanks for the info. 10's are moving enough for me so that sounds great.
Old 06-06-2009, 08:47 PM
dhdenney's Avatar
Yeah I think I have read that the XL has been lightened considerably and should be considered in N/A apps.
Old 06-07-2009, 05:20 PM
longrange4u's Avatar
Maybe I am bias but my PT88 works great and spools near instantly... I will agree however if I was to do it ALL over again... I may have gone with a different turbo, but S series turbos werent out when I bought my 88... I also catch that he is a M6 not an Auto like my setup... Running a 408 with fully wrapped exhaust all the way back... I would say go with the turbo you guys put in Zombies.
Old 06-07-2009, 08:16 PM
eviltwin_1987's Avatar
+1 on the 370. You definatley don't need a 408 to make the numbers you want.
Quick Reply: 408 w/STS build pending Opinions welcome
