Truck manifolds have very different size openings (40%) - isn't it a problem?
Old 05-07-2009, 08:04 AM
Vetal's Avatar
Default Truck manifolds have very different size openings (40%) - isn't it a problem?
As title says... Truck manifolds have very different diameter openings, difference in area is 40% which is quite a lot and will cause difference in backpressure and respectively EGT.
Do you guys enlarge the smaller one, or do you just ignore this?
Old 05-07-2009, 10:48 PM
phoenix's Avatar
subscribing.
Old 05-07-2009, 11:03 PM
LS1Silverado05's Avatar
I too would like to know this...and what is the reason for it like that in the first place??
Old 05-08-2009, 12:00 AM
Lopoetve's Avatar
Dot for me too
Old 05-08-2009, 12:57 AM
wilson34's Avatar
yessirrrr
Old 05-08-2009, 02:28 AM
Vetal's Avatar
yes, and that too...
Old 05-08-2009, 07:06 AM
smokinHawk's Avatar
i dont think anyone has had a problem with them that way
Old 05-08-2009, 08:18 AM
Denali08's Avatar
I think Josh of KY Turbo will chime in. He is the truck manifold turbo guru.
I don't think some good porting will hurt.
Old 05-08-2009, 01:19 PM
BlwnLs1GTO's Avatar
I have a set of these and was wondering the same thing. I was just planning on opening
the other side up a little. Mine is about 1/4" difference between the two.
Old 05-08-2009, 04:02 PM
Vetal's Avatar
I think that's partly because you can't really see/measure problems caused by these manifolds. But if 2 banks breathe differently, I'd say it can't be good. Didn't anyone ever burn passenger-side pistons? Wasn't it partly due to higher EGT in this bank?
I hope some gurus will shed some light
Old 05-08-2009, 08:20 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
I'm sure you would want them to flow evenly. I wonder how many people actually have touched them though. I've never heard of anyone openly saying they ported them.
Old 05-09-2009, 12:02 AM
frcefed98's Avatar
Ohio boys have been to over 1000rwhp on em....and into the low 8's or high 7's on em, can't remember exactly.
I think you will be fine.
Old 05-09-2009, 04:56 PM
Vetal's Avatar
What size pipes to turbo (TC78) do you think I should use for maximum top-end power?
Quick Reply: Truck manifolds have very different size openings (40%) - isn't it a problem?
