Check out the difference in numbers between our Mustang Chassis Dyno and a Dynojet
Old 05-07-2009, 08:32 PM
EPP
EPP's Avatar
Thumbs up Check out the difference in numbers between our Mustang Chassis Dyno and a Dynojet
http://forums.corvetteforum.com/c5-f...-at-10psi.html
Check out the difference in numbers between our Mustang Chassis Dyno and a Dynojet Dyno, in the above link. This one was a shocker. Bob
Old 05-07-2009, 09:48 PM
tirefryin_s10's Avatar
I put a cobra that made 523 rwhp on a mustang on my brand new dynojet 224x today and it made 553 ..... Seems to me like something is up there?
Old 05-07-2009, 10:53 PM
That's what she said...
TheBlurLS1's Avatar
Mustang dyno may have been tight, while the Dynojet a bit loose, more air in the tires on the Dynojet, no fan on the intercooler on the Mustang dyno, may have had wheelspin on the Mustang dyno, the list goes on and on lol.
I bet it goes 140mph+ at the track though, and that's all that counts in the real world.
Old 05-08-2009, 07:02 AM
BLNLS1/RX7's Avatar
Bob,Which dyno do you think repersents the real numbers?
Old 05-08-2009, 08:37 AM
Shearer's Avatar
Mustang Dyno numbers can be played with quite easily...
Old 05-08-2009, 09:32 AM
RealQuick's Avatar
Good example of the usual theory that mustand dyno numbers are ~10% lower than dynojet.
Old 05-08-2009, 11:50 AM
The problem is this will constantly turn into an argument between "Mustang" dyno guys and "Dynojet" guys.
The numbers do not matter, the dyno is a tuning tool plain and simple.
Old 05-08-2009, 01:49 PM
Zombie's Avatar
They only real dyno that is a measure of performance doesn't fit in a building, it's 1320' long. I ignore the "Horse Power" numbers I get on the dyno with my car except for seeing if a change I've made makes the graph go up/down or change shape. Adding a trans like a Th400 into the mix makes the numbers and graph shape even more interesting.
Old 05-08-2009, 04:27 PM
flawless35th's Avatar
mustang dyno has wind resistance at speed factored in for each vehicles factory specs and it has an inertia resistant roller
Old 05-08-2009, 06:01 PM
BLNLS1/RX7's Avatar
By chance did you stay at a holiday inn express last nite?
Old 05-08-2009, 06:37 PM
WS6HUMMER's Avatar
Wow thats a big difference!
Old 05-08-2009, 07:13 PM
Floader's Avatar
That is some funny ****
Old 05-09-2009, 06:22 AM
EPP
EPP's Avatar
http://www.exoticperformanceplus.com/hotCars.php?car=44
Steve, check out what this drag car did on our dyno running the 1/4 mile, and then what it did at the Texas Motorplex several days later. Bob
Old 05-09-2009, 07:45 AM
2001WS6Vert's Avatar
I can give you another comparison. Awhile back Brent dyno tuned my car at EPP. It made 650, I then had it dynoed on a Dynojet with no changes and it made 687.
Old 05-09-2009, 07:59 AM
WAHUSKER's Avatar
Interesting Bob. I've heard the 10% dif before, but I also thought WinPep 7 for the DynoJet corrected some of that. Looks like your Mustang is dialed in pretty close by the 1/4 numbers.
Old 05-09-2009, 10:11 AM
eb02z06's Avatar
Bob didn't you post a while back that C6 Z06's dyno 430 rwhp on your dyno? On our Dynojet they only dyno 435-440 rwhp-FWIW.
Old 05-09-2009, 10:38 AM
SilverSS's Avatar
I guess my car should be making 825rwhp then with my D1SC on a dynojet.........cool....
Old 05-11-2009, 04:55 AM
EPP
EPP's Avatar
Thumbs up
Yes indeed, 430-432rwhp. It sounds like you have an eddy current Dynojet, if you don't, it's really conservative. Bob
Old 05-11-2009, 11:01 AM
scramblerman's Avatar
I had EPP run a 1/4 mile on my ws6 more than a few years ago. I ran pretty much the exact time, 12.8 at 108mph when I had no wheel spin at the track. So that dyno is pretty damn close to real world results.
Old 05-11-2009, 11:53 AM
1320's Avatar
interesting...... I actually tried to find this thread yesterday I think. Sat night we dynoed three cars. All on an all wheel drive mustang. We ofcourse use it as a rwd only. Its common that if you dyno on it in vegas that youll probably get your lowest numbers. No big deal to me, its for tuning. I dont even care if it measures hp or garflabs.
Anyways, as the cars dynoed, in a over 100 degree shop, all the numbers where slightly low. Only slightly, like 5 - 10 % compared to other people dynojet numbers. Anyways, two of the three are geared really high. All m6 cars, one with 3.42's and a 29.4 inch tall tire, one with 3.08's and the m6...All pulls were in 4th gear , and those two made pulls to 155 mph in 4th gear.
Since mustangs account for speed....what do they account for? How does it change the results? I ve expirimented with changing weight with out much change in results. The mustang seems to be very consistent, the basic reason I like using it.
In the past, Ive seen a car dyno 539 on the mustang I speak of, and 669 on a dynojet across town. The owner thought it was going to make over 700 on teh mustang. There is another dyno in town that I can only guess is about 2x high......but lots of happy customers.
Zombiess car has only made 600 once on the mustang, but runs 136 mph @ 3890 lbs.
go figure.
Quick Reply: Check out the difference in numbers between our Mustang Chassis Dyno and a Dynojet
