Help, Compressor housing leaking.
Old 05-08-2009, 07:17 AM
WS6HUMMER's Avatar
Default Help, Compressor housing leaking.
I did a leak test on my car and found that the compressor housing was leaking, its right around where all the bolts are that you would use to loosen to clock the cold side of the turbo. I tried tightening them and it helped but I still have a faint leak, is there anything I can do? Its a Garrett 76 btw.
