My Procharged 451 LSX build with Procharger F1C
I just got the engine in from LME Friday (Thanks Bryan).
LSX Block (9.5:1) compression
Callies Compstar forged 4340 4.100" crank
Callies Compstar 6.125" H-I beam rods w/ARP 2000 7/16 bolts
Wiseco forged 4.185" x 1.065" x -30cc
Total seal rings
Cam motion custom cam (.646,.621 lift) @ around 250 duration
ARP head studs
Cometic head gaskets
Yella Terra roller rockers
Ballanced and blueprinted
TFS 235 Heads (2.08,1.60) valves 70cc
TH400 trans rev. man. v/b with t/b
3500 vig. stall
Procharger F1C with big fmic
Don't have any pics yet, it's still in the box! Should be starting on it this Monday.
I plan on running as much boost as i can on pump gas. The main thing i need to find out is WHAT SPARK PLUG SHOULD I USE? I was told NGK TR7's but i need the stock number so i can get them on order. I have seen there are SEVERAL different kinds (iridiums, projected tips, non projected tips) the list goes on and on....... too many choices. Which ones would you use? I need advice from people that have been there and done that. Thanks in advance!
Oh i'll post pics as the build goes on.
Total seal rings
ARP head studs
3500 vig. stall
Ha ha. You must have seen the pics of the last setup. lol I sold the nitrous and going to compensate for the removal of the nitrous with a big cub.in. motor and the F1C!
