truck manifolds
Old 05-10-2009, 01:42 AM
droksformula's Avatar
Default truck manifolds
Hello, I want to use the tried and true truck manifold set up for my turbo build. I have a fully built 382ci and im using 317# heads, of course lq4/9 manifolds will bolt up, but what about manifolds from 2008,9 trucks? They use l92 heads I believe, are the exhaust ports so different that that the two would not match up or is this not a issue? Also do you guys use the factory exhaust gaskets (between heads and manifolds) in these high hp builds or do you use something fancy like kooks or sce? Thanks.
Old 05-10-2009, 04:28 PM
Anybody ? All you guys in here with these setups,one of you guys got to know.please.
Old 05-10-2009, 07:14 PM
SScam68's Avatar
https://ls1tech.com/forums/forced-in...t-up-faqs.html
IBTL
Quick Reply: truck manifolds
