Oil return line IDEA for STS
Old 05-10-2009, 06:04 PM
brianfromhawaii's Avatar
Default Oil return line IDEA for STS
I am not going to run my oil return back into the cap... I am going to run my oil return into one of the nipples for the PCV system and put breathers on it... I dont have emissions where I live... Anyone see a problem with this?
Old 05-10-2009, 06:14 PM
TS6
TS6's Avatar
Don't see why it won't work
Old 05-10-2009, 08:56 PM
I think it will I took the valve cover off. Looks good.
Old 05-10-2009, 09:44 PM
Big_Bird_WS6's Avatar
or a local guy just taped the valve cover and ran it in there
Old 05-11-2009, 12:40 AM
shawn_c992001's Avatar
Exactly what I did.
Old 05-11-2009, 03:12 AM
thats not too much oil in one valve cover? Buddy said I should tap the oil pan.
Old 05-11-2009, 09:00 AM
just make sure you stay above oil level line.
Old 05-11-2009, 09:52 AM
great421's Avatar
Default My Idea
A second thought:
I purchased set of stock valve covers, and I placed the (second) Pass side cover on my Driver's side, so now I have a way to run a PCV port on the DR side (Tee'd into the PCV line from the Intake) and I have a second oil filler neck, so the issue of dealing with the oil return line (when adding oil) is solved too.
Just an idea to consider as well...
Old 05-11-2009, 10:51 AM
With the set up from STS it runs back to there any way.
Quick Reply: Oil return line IDEA for STS
