Do i have to lube my Procharger idler pulley or stock idler pullyey
Old 05-11-2009, 05:10 PM
BigRich954RR's Avatar
Default Do i have to lube my Procharger idler pulley or stock idler pullyey
Ok I was doing work on car and engine today. There is a sound coming from i think is the procharger idler pulley not sure. Trying to find ways to pin point it. Sounds kind like a dry bearing not broken or loose. maybe a little bit of a screeching sound very litttle
Old 05-11-2009, 10:31 PM
BadgeZ28's Avatar
sounds like the idler for the stock accessory drive just behind the J bracket. Remove the procharger belt and see if the noise is still in that area.
Old 05-12-2009, 10:12 AM
ls 2 goat's Avatar
Make sure the tensioner pulley isn't rubbing on the bracket; the belt may have become too lose and caused the tensioner to drop below where it should.
Old 05-12-2009, 10:20 AM
moehorsepower's Avatar
My bearings went south, I just went to my local bearing shop and replaced them, very easy, just need snap ring pliers..
Old 05-13-2009, 10:15 AM
CHIRODOC33431's Avatar
where could I go to get a new bearing for the tensioner pully, or could you e-mail me the number to the place you got yours. thanks Ernie
Old 05-13-2009, 01:00 PM
Dont know where you are located but I am in Texas and I went to what is called Purvis Bearings, I'm sure if you go to your local bearing shop they can match it up..
Quick Reply: Do i have to lube my Procharger idler pulley or stock idler pullyey
