Thread sealer on LS1 block?
Old 05-13-2009, 09:50 PM
Boo"SS"t's Avatar
Default Thread sealer on LS1 block?
Just a quick question concerning LS1 block: Do I need to apply any thread sealer on any of the head studs on the block side??? -Thanks in advance!
Old 05-13-2009, 10:14 PM
WS6HUMMER's Avatar
Good question, I'd like to know also. Bump.
Old 05-13-2009, 11:18 PM
98RedBird's Avatar
For the head studs just use the ARP assembly lube. That's all you should need.
Old 05-13-2009, 11:48 PM
Boo"SS"t's Avatar
So, are you saying that none of the threaded holes on the engine block actually goes thru any water jackets? I used to put thread sealer on my LT1 application but not sure on the LS1 if I have to.
Old 05-14-2009, 12:34 AM
kp
kp's Avatar
The head bolt holes are blind, no sealant needed.
Old 05-14-2009, 08:25 AM
Boo"SS"t's Avatar
Thanks!
Old 05-14-2009, 08:59 AM
Dumb Ass Vette Moderator
ls1290's Avatar
Yep, just a slight amount of assembly lube is all that is needed.
Old 05-14-2009, 04:20 PM
98RedBird's Avatar
Yep, as the others said, the holes are blind. No worries man.
Old 05-14-2009, 04:24 PM
99Ls1fever's Avatar
Good Info, thanks for starting the thread
Quick Reply: Thread sealer on LS1 block?
