F1 Install: 370 CI Lq4
Old 05-18-2009, 06:58 PM
KrisXpc's Avatar
Default F1 Install: 370 CI Lq4
This is Operation Black hole..
My 98 Camaro Z28 A4 GU5 turned 2002 PCM / SS cloneish / 6 speed.
!Molding, Shaved camaro letters on rear, SS spoiler, 18's ZO6 motorsport, VFN Sunoco hood. Trans Am interior.
AEM wideband o2 POD, Cobalt Boost and Fuel PODS. Passenger side laptop stand W/ EFI Live.
The engine has MLS gaskets and wiseco 15cc dish pistons. Scat rods yada yada....
Compression is right around 9:1 @ 15 psi I should (Hope) make 700-750ish Hp
Lq4 truck Heads with some work to them. Comp custom grind cam. Fast92/92
F1 Procharger W/ Twin intercooler setup. 8 Rib upgrade. Pullied for 15 psi.
Currently trying to build my own 1000 hp Fuel system, And install A Meth kit
This is my daily driver when im not riding the Bike.
I can't wait to post some numbers up!!
Old 05-18-2009, 07:01 PM
KrisXpc's Avatar
Im going to post pictures as the install goes along.
Old 05-18-2009, 07:40 PM
calongo_SS's Avatar
For the fuel system call Lonnies, he'll get you everything you need. I would recomend a BR FPR with dual pumps. 15 lbs should get you there pretty easily, I'd run meth as well for safety's sake.
Old 05-18-2009, 08:41 PM
venom ws7's Avatar
15psi+ to get 700rwhp but depends on these question below
what trans?? rearend are you running???
Cam??
great build BTW keep us posted.
Old 05-18-2009, 10:04 PM
Rickys S/C Z28's Avatar
sweet man good luck with your build
Old 05-19-2009, 12:03 AM
KrisXpc's Avatar
Progression of the car in its "Stages"
Old 05-19-2009, 12:04 AM
KrisXpc's Avatar
http://www.youtube.com/watch?v=aEe1PBAcgzI
Cam only when it was an A4 stalled car
Old 05-19-2009, 12:09 AM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
I can talk you through most of it. Hint call Hint. I'll give you all of the updates.
The engine has MLS gaskets and wiseco 15cc dish pistons for 6.125 rods. Compression is right around 8.9-9:1 depending on the in / out of the hole measurements that I have no idea on.
For the fuel system I would run a -8 feed and a -6 return. 60lb injectors should get you there, but be some what close to max duty cycle depending on what fuel pressure you are running. 2 Walbro 255s should have you covered fuel pump wise. Mighty Mouse has a sticky in the fueling and injection section that details the install process. His write up is for a 98 too so its a bonus. Stock rails aren't adequate at that level. You'll definetly need different ones.
A really good option is using 1/2 inch steel tubing like Jason did on the mustang. It is right around the siz e of -8 line, but much cheaper.
Getting good at using EFI live yet?
Old 05-19-2009, 12:14 AM
KrisXpc's Avatar
Now for the current build up.
Old 05-19-2009, 12:21 AM
OWN3D BY MY PROF!
^ I remember those stages.
Old 05-19-2009, 12:39 AM
OWN3D BY MY PROF!
I just did some number crunching. 60 lb injectors are good for about 709 hp at 80% duty cycle and .625 BSFC. That's crank hp. You could jack up the fuel pressure, but that strains the pumps. I would get these:http://fuelinjectorconnection.com/sh...d&productId=19
At 58 psi, .625 bsfc, and 80% duty cycle they are good for 945 crank Hp. Those should fit your goals perfectly and they are priced pretty well to boot.
Old 05-19-2009, 01:04 AM
KrisXpc's Avatar
Not bad. I need to get some pics up of the F1. I had all the pipes zinc and powder coated gloss black. They look super sexy
Old 05-29-2009, 03:32 PM
KrisXpc's Avatar
Went with motron 60# that I scored pretty well priced.
Ill be doing the Fuel upgrades hopefully tthis weekend..
Ls1 speed is being slow to deliever my goods...
Old 06-20-2009, 08:10 PM
KrisXpc's Avatar
Some progress with the car. 12 hours of work, 2 Friends, LOTS of beer..and the procharger was installed...
My ls1 speed fuel rails cross threaded on install and leak fuel... So no startup video.
When the rest of my fuel lines and regulator come in ill be installing the fuel system and my car should be good to go for some dyno numbers!!
Old 06-20-2009, 08:36 PM
brandon619's Avatar
You are going to love the top end pull from that F1
Old 06-20-2009, 09:07 PM
KrisXpc's Avatar
Your out in San diego aswell?? ^^
Where are all the meets at?
Old 06-21-2009, 06:32 AM
SELLSZ06's Avatar
looks nice, but you should do a frontmount instead of those 2 coolers. it would be a lot eazier gor your goals
Old 06-21-2009, 10:28 AM
brandon619's Avatar
Hey Kris, I really don't hangout once a month I run with MVCC crew and hang out at breakfast at Balboa once in a while. Who is doing your tune? I hope you are Speed Density?
Old 06-21-2009, 12:33 PM
'Trust''s Avatar
60's are pushing it for that much power. Here is what I would do (my setup basically):
Twin Walbro 255s in-tank
Acceleronics Driver Box (only if you're running low impedance injectors, they are just easier to tune and when you get up there in lb/hr they are more predictable)
75lb/hr Low Impedance Injectors
FAST Fuel Rails
Aeromotive Boost Referenced Regulator
Braided Return
Without meth, I would agree. But I am still on the twins and they seem to be making the power okay .
Old 06-21-2009, 07:26 PM
KrisXpc's Avatar
I have tuner in northeast florida doing the base tune. Im a super newb with EFL Live, but I plan on runing A SD COS
Im still clueless on who will do the final dyno tune out here. Who is the "big name" local tuner?
Id prefer to have someone experienced with EFI live do the tune.
Quick Reply: F1 Install: 370 CI Lq4
