View Poll Results: which turbo?
go with the t76gts
12.50%
go with the gt47-88
87.50%
Voters: 8. You may not vote on this poll
trade t76gts for gt47-88???? yes or no
Old 05-20-2009, 11:49 AM
02anti_vnm's Avatar
Default trade t76gts for gt47-88???? yes or no
ok i have a forged 347, 317 heads, custom cam, truck manifolds and a fuel system to support a 1000hp
my setup is pretty much finished thanks to alot of help from guys in this section... thanks again guys!!
but now the question is i have a precision t76gts that i have been offered a precision gt47-88 for
both have same miles and everything and its a straight up trade should i do it? or not?
to help this will be a street car on about 16-18psi
im worried about the spool time for the gt47-88 but figured the greater mass of air from the greater size would make up for it...
keep mine or go bigger?
thanks!!
Old 05-20-2009, 12:00 PM
icedenali's Avatar
do u have turbo lag now with 76? 88 will give u more HP at top end, but u have to think about lag. also what's ur redline on ur engine. and when does ur 76 spool up and max boost by what rpm?
i seen gt42-88 making 1000whp to supra engine but it's bit laggy with 3.4liter.
but since u have forged 347 u shouldn't worry too much about lag..
Old 05-20-2009, 12:01 PM
Smearin's Avatar
You could always use a lower exhaust housing to shift that rpm range on it
Old 05-20-2009, 12:16 PM
black98ws6ta's Avatar
apples to apples the 47-88 is going to spool slower...just depends on what your looking for. The 76 gts will be quick spooling and make quite a bit of hp.
Old 05-20-2009, 12:35 PM
LS1TECH Sponsor
DrTurbo's Avatar
thanks!!
How much HP do you want???
Old 05-20-2009, 01:17 PM
02anti_vnm's Avatar
Its not running right now I'm just finishing up the build but from what I heard the t76 should take long to spool at all maybe full boost at 3000?? But I really have no particular hp goal in mind maybe 900? Its mostly just bragging rights since 900 won't hook on the street anyways but I was told the 76 would max at 750. Don't get me wrong 750 is A LOT! But like I said I'm chasing those 900hp bragging rights
Not just the small cubes but the fact that it will be a t4 flange with an adapter plate to feed the t6 flange of the 88 will that also make it harder to spool?
Thanks!
Old 05-20-2009, 01:20 PM
LS1TECH Sponsor
DrTurbo's Avatar
Stick with the 76GTS ...sounds like you have a true street car....not a street strip terror. The 76GTS will make 1000crank HP no problem. If later you want to make the push for more power, then opt for the GT47 now. Also a GT47 with a .96A/R housing will spool VERY nicely if set up correctly. You don't want to re-make a kit again...PITA.
Old 05-20-2009, 01:50 PM
themailman's Avatar
I agree with DrTurbo.
You really don't need 1000rwhp or even close. The fact that you ask that question makes me think you don't really know much about turbos, which isn't a bad thing. Bigger isn't always better.
I think it's like a buffet. You see an oppertunity to up the max hp potential, but it's more than you can eat right now. I'll keep the GT47-88 and buy some flanges and stuff from Forced Inductions, and then everyone is happy.
Old 05-20-2009, 02:22 PM
02anti_vnm's Avatar
Sorry man I'm a little confused by the last part would a t6 addapted to a t4 not cause a spooling problem?
Old 05-20-2009, 07:59 PM
02anti_vnm's Avatar
I've decided I'm just going to keep my 76 750-800 in a street car truely is more than enough and with the almost instant spool time it should be pretty nasty!
Thanks for the help guys
Old 05-21-2009, 12:00 AM
Turbo6Speed's Avatar
Good choice
Old 05-22-2009, 07:07 AM
ohshixgoat's Avatar
you can always upgrade you housing and wheels to a 80 gts at forced inductions...talk to jose...I have a 80 gts that was a 76 gts
Old 05-22-2009, 09:20 AM
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
I was told that is no longer being done.I believe some had balancing issues or something like that with that upgrade.
Old 05-22-2009, 10:17 AM
LS1TECH Sponsor
DrTurbo's Avatar
No it was availability. Garrett stopped making the wheel.
Old 05-22-2009, 11:49 AM
ddnspider's Avatar
ah...gotcha.I remembered there was a reason it was stopped.
