What fuel pressure Regulator that rises with Boost/1000rwhp/what are you guys running
Old 05-22-2009, 05:04 PM
BigRich954RR's Avatar
Default What fuel pressure Regulator that rises with Boost/1000rwhp/what are you guys running
Looking for a fuel pressure regulator that rise with boost good till little over 1000rwhp
Wondering what some of the guys here are running for the Regulators. Im just about to do the MM dual pump setup on the cheap
Plus what the max PSI that can be run on the 60lbs injectors?
Old 05-22-2009, 06:03 PM
MY99TAWS6's Avatar
Mine is fuelab but any quality one should be just fine.magnafuel,etc. I have Lonnies complete setup twin intank,rails ,bigger lines,reg ,filter. Sure my current system can flow great just wish could drive my car have some other issues right now.
Old 05-22-2009, 11:44 PM
Louis's Avatar
Standard Aeromotive 13111 I think? I run a base pressure of 80 on the 60s if its a big build, I do not run them If I plan on making 1000 hp.
Old 05-23-2009, 12:50 PM
stevieturbo's Avatar
Magnafuel make nice regs....as do others of course.
60lb injectors wont see 1000rwhp safely at all
Quick Reply: What fuel pressure Regulator that rises with Boost/1000rwhp/what are you guys running
