oil return line question
i am having issues figuring out what drill size and tap to use for a -10 an fitting, should i use a NPT fitting to an -AN fitting?
idk wat to do,
what do you guys have goin on? and is it something i can go to home depot for?
thanks
idk wat to do,
thanks
running -10 from my turbo's to an AN to NPT fitting screwed into either side of the pan just above the oil level sensor. Dont think this is something you can pick up at the depot. Have to check the drill and NPT tap size and get back to you.
