What spark plugs and fuel to run in 14 psi ls2
Old 05-26-2009, 04:29 PM
BigRich954RR's Avatar
Default What spark plugs and fuel to run in 14 psi ls2
Ok going to get my car tuned again.
last tune i ran out of fuel at 5k rpms at 9psi and 600 hp
was running meth and 93 pump with spark plugs tr6
new fuel pumps in taking her up 6800 rpms this tune. stay with same spark plugs ? Still going to run same amount of meth but is it worth added some C10 in a 50/50 mix or 100 C12
Old 05-26-2009, 04:56 PM
dpinson's Avatar
i would try to leave the race gas out so you dont have to worry about that
unless you dont care and just want the most power possible
Old 05-26-2009, 05:04 PM
not worried . I have 80 gals of c12 that i need to burn up in next 2 months before i go to Iraq for a few months
Old 05-27-2009, 05:46 AM
EPP
EPP's Avatar
We use the NGK TR6 4177 spark plugs in your boost range, which are probably the plugs you have. Bob
Old 05-27-2009, 07:07 AM
LS1Tech Sponsor
hellbents10's Avatar
Race fuel never hurts for safety, that is how Dave is on his second year at 825++whp with his 05' GTO on a stock LQ9.
Old 05-28-2009, 08:13 PM
What race fuel is he running ?
Old 05-28-2009, 08:43 PM
Texas Heat's Avatar
I run TR6's and straight 93 octane pumpgas with no issues.
Old 05-29-2009, 12:18 PM
Drewstein's Avatar
I went to TR7 and run 91 with no issues.
Old 05-29-2009, 01:02 PM
GET8UP's Avatar
15psi on 93 octane and I run TR6's gapped at .25 with no problems...
Old 05-29-2009, 01:32 PM
Zombie's Avatar
I just swapped to a NGK 7 heat range non protruding tip plug at 15psi and really like it. It comes pre gapped at .028 which is nice. Much better than having to squish down a normal plug gap. Don't remember the number off the top of my head tough, nappa carried them.
If you are interested I can find the number for you.
Old 05-29-2009, 01:46 PM
AFASTYZFR1's Avatar
Me 2
Napa #3346
Old 05-29-2009, 03:22 PM
Zombie's Avatar
Originally Posted by AFASTYZFR1
Me 2
Napa #3346
NGK-3346-BR7EF Is the correct part number
Old 05-29-2009, 04:17 PM
AFASTYZFR1's Avatar
Napa stocking #
Love these plugs.....bought a few spare sets cause they are a little hard to get
Old 05-29-2009, 04:27 PM
Restricted User
98Z28CobraKiller's Avatar
I run an 8 with regular tip gaped at 028. NGK 7317
Old 05-29-2009, 05:08 PM
Well guys Thanks for the Info Full tank of C16 went home to eat and motor blew up in driveway. Didnt even make it to the dyno. Good news is i have a new shortblock sitting in backroom. Was just hoping to get one more month out of this motor
Ill be putting the the #7 in for new motor
Old 05-29-2009, 11:11 PM
Darren P's Avatar
I am running TR6 with 15 PSI right now, will most likely switch to TR7 soon
hdumdumdum
Old 05-30-2009, 07:53 AM
AFASTYZFR1's Avatar
hdumdumdum
I actually burned a grounding strap off of a tr6 with 16psi.......put in a set of TR8's but they interfered with my radio and bcm......so I got the 7's and they have been working great
Quick Reply: What spark plugs and fuel to run in 14 psi ls2
