Replaced the Injectors & Alternator = A/F is RICH! Turn up the boost?
Old 05-27-2009, 01:26 PM
Monello's Avatar
Default Replaced the Injectors & Alternator = A/F is RICH! Turn up the boost?
So I installed new 42lb injectors (Stock 28lbs now 42) that I had reflowed. I also replaced the alternator with a 140amp with totally new 1 gauge cables for everything. The original cables were corroded really bad, so thats why I was only seeing 10 to 11 volts. Now the car is seeing 13-14. The original injectors were lucas 42lbs.
WOT is now 10.5 A/F
Currently the car is running off the wastegate spring which is 5.5. Can I turn up the boost abit without having to retune it? Looking at getting a tru-boost. What should the target A/F be?
Old 05-27-2009, 01:42 PM
HUNTER02SS's Avatar
Yes, that will lean out the WOT, but you will still need to get the car re-tuned for the drivability. I am sure it richened up on the low end as well.
Old 05-27-2009, 04:40 PM
stevieturbo's Avatar
Just get it tuned properly.
Old 05-27-2009, 04:56 PM
TS6
TS6's Avatar
Uh yeah, you can't just swap injectors without a retune. I wouldn't even drive it, you could wash the rings out.
Old 05-27-2009, 05:17 PM
TurboBandit's Avatar
... wash the rings out?!?! what are you talking about? Is this honda-tech?!
Were you tuned on 5lbs with the stock 28lbs injectors???
If so, yes you can turn the boost up a little bit, but your driving out of boost is going to SUCK and you're going to get 6 miles a gallon. May foul out a plug.
On the brighter side... if you had any small exhaust leaks, they're all soon to be clogged up with carbon!!!!!! (with all that unburnt fuel that you're dumping in)
Old 05-27-2009, 07:17 PM
TS6
TS6's Avatar
Look it up, its what happens when you run excessively rich. Hell, even the boys on Honda tech probablt know that.
Old 05-27-2009, 07:27 PM
98Camarod's Avatar
Monello, did you change the IFR table for the new 42.5lb injectors? Do you have a boost ref regulator, I don't remember.
Old 05-28-2009, 09:31 PM
98catfish's Avatar
WOT is now 10.5 A/F
he said he just had stockers reflowed to 42s.
Just up the boost 1# at a time and monitor a/f and you should be fine.
Going from low voltage to a proper voltage would definitely make the fuel pump flow more so I can see the rich condition.
just dont make any big boost changes, do a little at a time.
Doug
Old 05-29-2009, 12:41 AM
LS1Silverado05's Avatar
WOT is now 10.5 A/F
I am also interested on what you guys say to this...
Old 05-29-2009, 02:08 AM
Phat69's Avatar
depends on the car really
Old 05-29-2009, 03:27 AM
ALTRDTA's Avatar
11.5 afr is a good safe tune. If you wanna push it go 11.7 to 11.9...
Old 05-29-2009, 09:33 AM
Monello's Avatar
Think i confused everyone. The car had 42pound lucas injectors, but I got my stock 28lb injectors flowmatched so I took out the lucas injectors and installed the stock reflowed to 42lbs.
The reason the car is richer is it was tuned when I was having electrical issues. So the fuel pump was barely seeing 11 volts. After replacing the coroded power cables and new 140amp alternator, it now sees 13-14 volts.
Old 05-29-2009, 10:34 AM
Makes sense to me.. so now it needs a retune now that the pump has the juice..
Old 05-29-2009, 10:43 AM
98Camarod's Avatar
I definitely mis read it. But now you need a retune cause you are getting some new found fueling.
Old 05-29-2009, 10:55 AM
TS6
TS6's Avatar
Hold on though, you had Lucas 42# injectors, now you have stockers that were flowed to 42 lbs. Were those both rated at the same psi? Reason I ask is because most injectors are rated at a given psi and our LS1's run higher fuel pressure than what most are rated at. For example, lets say your Lucas were rated at 42# at 58 psi; now lets say you had your stockers made into 42# at 40 psi; running those modded stockers at 58 psi would make them more like 60# (guessing here).
Your voltage thing is also very likely, just wanted to check on those injectors.
Old 05-29-2009, 11:24 AM
98Camarod's Avatar
^^Good question, just FYI, the 42.5lb lucas injectors with 58 psi act like 49.05lb injectors.
Old 06-07-2009, 01:41 PM
MUSTANGBRKR02's Avatar
How much did that cost and who did it?
Old 06-07-2009, 04:37 PM
why not just buy proper injectors instead of ******* about like that ?
Old 06-07-2009, 07:31 PM
Louis's Avatar
Old 06-08-2009, 08:14 AM
Dumb Ass Vette Moderator
ls1290's Avatar
How are you so wise in the ways of science young man
Quick Reply: Replaced the Injectors & Alternator = A/F is RICH! Turn up the boost?
