turbo oil return
Old 05-31-2009, 11:48 AM
ccrider's Avatar
Default turbo oil return
anyone use the oil level switch hole on the side of the pan for a return?
Old 05-31-2009, 01:40 PM
ForcedInduction's Avatar
cant, oil level is above the sender even while running. (this is why the sensor is there) turbo will never drain. has to be above the oil level "line". I ran mine into the front cover.
Old 05-31-2009, 01:58 PM
ccrider's Avatar
thanks-you tapped into the front timing cover?
Old 05-31-2009, 02:06 PM
spaz1's Avatar
Mine is tapped into the pass side valve cover.... for my sts kit.
I know this isn't the best but it's better than the shitty cap they give you. I didn't feel like dropping the front k member and oil pan... Maybe one day.
Old 05-31-2009, 06:06 PM
yes, pic attached..
Old 06-01-2009, 12:38 PM
ccrider's Avatar
my turbo is going to be lower than the front cover, but the oil will be under pressure so it should still flow ,correct?
Old 06-01-2009, 12:50 PM
it wont, you will need a pump to reurn your oil of you turbo is below the oil level line
Old 06-01-2009, 12:55 PM
ccrider's Avatar
what kind of pump would i use? and thanks for all your help
Old 06-01-2009, 01:37 PM
Slo_240sx's Avatar
Some type of scavenge pump to pump it back into the pan since it wont gravity drain.
Old 06-01-2009, 02:49 PM
ccrider's Avatar
looks like it might be cheaper to repipr the turbo,cheapest pump i've found is over $200.
Old 06-01-2009, 05:11 PM
spaz1's Avatar
mocal makes a good pump.
Old 06-06-2009, 10:17 PM
mk1973's Avatar
I was planning on doing the same thing, I have a fitting that screws into the pan metric thread to 1/2" NTP. the fittings where not cheap and I have a spare if your going to go that rout shoot me a PM...
Old 06-06-2009, 10:40 PM
svg210's Avatar
link to that please?
Old 06-22-2009, 03:28 PM
Restricted User
speeddemon651's Avatar
remember the pump will be one more thing to go bad, some guys don't have any trouble with them and several others have had nothing but.
Quick Reply: turbo oil return
