bmw twin scroll twin turbo
Old 06-01-2009, 04:31 PM
ayousef's Avatar
Default bmw twin scroll twin turbo
Well, seems someone finally did it, I never expected BMW to do it though, but what a brilliant design for those who read about it, beginning with a V engine and ONE exhaust manifold.
It would be very interesting to see more and more people come up with a twin scroll twin turbo designs which BMW has proven to be very competitive.
A few facts:
Both the new BMW X6 M and BMW X5 M, set to debut this week at the New York Auto Show, are powered by a newly-developed 4.4-liter V8 M engine delivering 555 HP at 6,000 rpm and 500 lb-ft o' torque from 1,500 to 5,650 rpm. The new M engine is the first with a pulse-tuned exhaust manifold encompassing both rows of cylinders combined with high-performance twin-scroll twin turbo technology.
full boost or 1.5bar of boost all the way from 1500rpms to about 5700, and drops a tiny bit after that. With torque dropping after 5700 and max power at 6000, looks like an indirect way to lower the max HP number on paper, while making equaivalent power of a ~600HP vehicle.
Torque is LITERALLY flat from 1.5k to 5.7k and as a result, power increases linearly to redline, even though the car has absolutely no problems with power delivery through its 4x4 system.
NOT AN LS, but something very interesting to share, hope we could argue this design
Old 06-01-2009, 04:47 PM
My2kz28's Avatar
very interesting...got any pics?
Old 06-01-2009, 09:37 PM
Hennytime's Avatar
good lord it looks like a nightmare
Old 06-01-2009, 10:01 PM
Yelo's Avatar
Where's the intake ??????
Old 06-01-2009, 10:51 PM
Eddiep's Avatar
Looks like it is on the outside of the heads - note the throttle body on the right side of the engine.
Old 06-01-2009, 10:52 PM
BlwnLs1GTO's Avatar
...With the engine block and oil pan.
Old 06-01-2009, 11:38 PM
73 nova guy's Avatar
direct injection it prob has some bokoo compression!
Old 06-02-2009, 12:41 AM
elias_799's Avatar
placing the turbos and the two manifolds next to each other where the intake manifold was supposed to be must keep the heat in very nicely. witch will help the spool times.
Old 06-02-2009, 07:07 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
So I'm guessing that essentially their exhaust exits where we have an intake manifold, and their intake manifolds are now twin intakes on the outside of the block.
Different for sure. Has any other v-block engine had this setup?
Old 06-02-2009, 07:37 AM
lt170chevelle's Avatar
wow..sounds like a killer motor..wonder what psi they were making that power at
Old 06-02-2009, 08:18 AM
Somebody09's Avatar
Did you bother reading the post, or did you only look at the pretty picture?
Originally Posted by ayousef
A few facts:
full boost or 1.5bar of boost all the way from 1500rpms to about 5700 ...
Old 06-02-2009, 12:21 PM
Adam Connell's Avatar
That is an awesome piece of engineering right there!
I am very intrigued by the dual twin scroll turbos. Im guessing that they use using 2 cylinders per "scroll" and using pairing them as close to 180 as possible to keep exhaust velocity up! Simply genius! I really am guessing at how this works though haha!
Old 06-02-2009, 12:57 PM
Gingervitis Addict
slow67's Avatar
Wasn't factory, but it has been tried.....
Old 06-02-2009, 01:05 PM
Johny GTO's Avatar
pardon my ignorance, but what is a "twin scroll" turbo? What is the difference between that and the run of the mill turbo?
This engine seems very impressive.
Old 06-02-2009, 03:39 PM
Hennytime's Avatar
a very basic idea is that there are veins that stay closed in low rpm operation to spool the turbo quickly like a smaller turbo, but then they open up in the upper rpms to produce big power like a larger unit. I'm not 100% on the technology so if I am off a bit, I'm sure some one will come along and correct me
edit, found this on a turbo forum:
A twin scroll turbine housing uses dual side by side passages into the housing. When coupled with a pulse converter manifold that separates exhaust pulses as many crank degrees in the firing order as possible, a twin scroll or divided housing works to reduce lag, decrease exhaust manifold backpressure on the top end, reduce the potential for reversion, and increase fuel economy. The twin scroll is based off the same reasoning a tri-Y header uses: keep spent exhaust gases out of an adjacent cylinder drawing in fresh air. At high rpm on a turbo car, exhaust backpressure is usually significantly higher than atmospheric pressure, and often higher than intake manifold pressure as well. A divider between each of the two volutes allows the cylinders to expel the exhaust gases without it interfering with the fresh air for combustion. Since there are two openings, each a smaller overall volume than a single scroll design, the exhaust velocity of each pulse can be maintained. This also spins the impeller more easily because lag is a function of the scroll area. A single turbine housing opening isn't as efficient since cylinders on the exhaust stroke of the 4 stroke cycle contaminate the cylinders that are on overlap with exhaust gas. A conventional turbine housing is not as effective in using exhaust pulse energy to help spin the turbine up to speed as it does not exploit the energy contained in the pulses as well.
Old 06-03-2009, 01:30 AM
Keith's Avatar
Probably the first time a Nailhead driving a 6-71 with a potvin has been posted here.
Old 06-03-2009, 01:08 PM
Gingervitis Addict
slow67's Avatar
I would have to agree!
Old 06-03-2009, 01:32 PM
krazy4's Avatar
Looks like a great idea!
It's boost is almost 22psi. Can't wait to see how much power these things start making when they tune 'em and get a full exhaust.
Old 06-04-2009, 09:26 AM
TiAL's Avatar
old F1 cars
Old 06-04-2009, 09:29 AM
TiAL's Avatar
turbine housing is split to allow for separation of exhaust pulses to stay divided and hit the turbine wheel 'cleaner'
this, when the engine is built correctly for it, gives a larger turbo better midrange response
Quick Reply: bmw twin scroll twin turbo
