View Poll Results: How long did your stock motor last with boost?
LESS than 1 year
7
26.92%
1 year
2
7.69%
2 Years
2
7.69%
2 years +++
15
57.69%
Voters: 26. You may not vote on this poll
How long did your stock ls1 last with boost????
Restricted User
I am curious to know how long your STOCK motor lasted with boost with stock compression.... with exception to springs, pushods, injectors, fuel pump....
Please reply with:
DD or Garage queen???
what psi you ran???
What was the RPM's did you run it up to???
How many miles (aproximately)???
Less than a year / 1 year / 2 years / 2 years + ????
How "SAFE" was your tune???
Intercooler / Meth / Both ???
Thanks for the input again guys!!!
Blaine
Please reply with:
what psi you ran???
Blaine
Please reply with:
DD or Garage queen??? In the middle. About 6000 miles last year. Not bad for Minnesota.
what psi you ran??? 8 lbs
What was the RPM's did you run it up to??? 5800
How many miles (aproximately)??? 6500
Less than a year / 1 year / 2 years / 2 years + ???? A little over a year
How "SAFE" was your tune??? Tune was pretty rich, not sure of the A/F though.
Intercooler / Meth / Both ??? Dual intercoolers
Still running though. Not sure if this helps.
DD or Garage queen??? Drove it to work some but mostly just on weekends
what psi you ran??? 7-9
What was the RPM's did you run it up to??? ~5800
How many miles (aproximately)??? ~10k
Less than a year / 1 year / 2 years / 2 years + ???? just over 2 years
How "SAFE" was your tune??? pretty safe, 11.2 afr was the leanest I went at the track. Most of the time it was in the high 10s afr.
Intercooler / Meth / Both ??? FMIC and meth.
DD or Garage queen??? DD so far and running good..
what psi you ran??? 8 lbs creep to 12psi
What was the RPM's did you run it up to??? 6000
How many miles (aproximately)??? 500
Less than a year / 1 year / 2 years / 2 years + ???? less than a year
How "SAFE" was your tune??? safe.
Intercooler / Meth / Both ??? intercooler
Still running strong!
Restricted User
thanks for the input and votes guys!
I like how you all are running more than 5psi and are still running strong! Have a feeling i wont stay there long though! LOL
DD or Garage queen??? Race car
What was the RPM's did you run it up to??? 6900
How many miles (aproximately)??? 60,000
Less than a year / 1 year / 2 years / 2 years + ???? 2-1/2 years-150 10 sec passes
How "SAFE" was your tune??? fairly safe until I put the meth to it & got greedy with ign advance then it went ka-boom
Intercooler / Meth / Both ??? FMIC most of it's life, meth the last month before it died as detailed above
DD or Garage queen??? DD in the warmer months
what psi you ran??? 7psi that came on the kit
What was the RPM's did you run it up to??? I did not change the redline. It's bounced off the limiter a few times.
How many miles (aproximately)??? Over 18k since the install
Less than a year / 1 year / 2 years / 2 years + ???? Installed fall 2007, still running strong!
How "SAFE" was your tune??? Safe Street Tune
Intercooler / Meth / Both ??? Intercooler
DD or Garage queen??? - Daily driver, Silverado RCSB 5.3 with Maggie Ford 9" with 3.89's and 4L60E with 2800 TC built by Finish Line Trans.
What psi you ran??? - 8Lbs, 5800
What was the RPM's did you run it up to??? 5,800 thru the traps at Last years Hot Rod Drag Week 12.53 / 108 MPH with a 1.71 60'
How many miles (aproximately)??? - I put the SC on and drove 5,400 miles to Drag Week and back home with more than fifty 1/4 mile runs during the week long event and since then have added another 12k of daily driving
Less than a year / 1 year / 2 years / 2 years + ???? - in August it will be 1 year
How "SAFE" was your tune??? - safe tune by Kenny Duttweiler on Magnachargers chassis dyno
Intercooler / Meth / Both ??? - Both, the IC comes with the Maggie kit and I added a Snow Meth kit per Kenny's suggestion
Building a new 7 liter Warhawk with new TVS huffer for this year Drag Week, engine is done and are waiting on the TVS to LS7 head tub then its out with the old 5.3 and in with some real HP - I need it to get my 4,660 Lb truck down the track LOL...
DD or Garage queen: DD comute to work + weekends
what psi you ran: 10lbs
What was the RPM's did you run it up to: 6200
How many miles (aproximately): 25,000
Less than a year / 1 year / 2 years / 2 years +: 2 1/2 years and counting
How "SAFE" was your tune: No idea. Tuned on the street by Rick at Synergy
Intercooler / Meth / Both: FMIC only w/P-1SC, FMIC + Meth with turbos
18k miles with a P-1SC and the last 7k with twin garrett GT3071r's.
Rick
Rick
DD or Garage queen???GQ
what psi you ran???14
What was the RPM's did you run it up to???7250
How many miles (aproximately)???1500
Less than a year / 1 year / 2 years / 2 years + ????less than a year
How "SAFE" was your tune???tune was good, "SAFE" isn't an option with stock bottom end and 14psi lol
Intercooler / Meth / Both ???fmic
