F1R 427 C6...numbers
After a long anticipated wait, we should be hitting the dyno this week. Previous build
HKE 427
ProCharger F1C
As cast LS2 heads
Stock LS2 intake
Dallas Performance fuel system
Dallas Performance Big Mouth inlet
Dallas Performance custom IC plumbing
8-rib pulley system
ECS dual nozzle Alky
RPM 3.42 diff
853rwhp/744rwtq @ 16#
New build
ETP LS7 4.1 heads
DP ported GMPP LS7 intake
Jesel rockers
Morel's
4" intake plumbing w/ integrated MAF
DP 10-rib system
Cartech Flip Drive
ProCharger F1R
1,002rwhp / 928rwtq @ 19#
No tricks - SAE Corrected - 93 octane - with the air filter on
Here is a before / after chart for the build
Dyno video
http://www.youtube.com/watch?v=7EY5oS2Mi30
In car idle video
http://www.youtube.com/watch?v=mKuC9n2k3oA
HKE 427
ProCharger F1C
As cast LS2 heads
Stock LS2 intake
8-rib pulley system
RPM 3.42 diff
New build
ETP LS7 4.1 heads
Jesel rockers
Morel's
DP 10-rib system
Cartech Flip Drive
ProCharger F1R
Dyno video
In car idle video
Will have to see. I expect to shift out of 4th at 155-158, that puts me at 5,000 in 5th. Will have to see how strong the engine is to pull 5th. 210mph is the goal.
John,
1000+ rwhp here we come!!! very nice build man... and the paint work looks killer!!!
the card maf is the BOMB... after that it's all s.d., the new stuff is changing things faaaaaaaaaaaaastttt, you'll see more and more of us that have been going this route...
I'm curious why the need for the maf card? Most boosted set ups go with a speed density tune, I'm missing something here?
SD on new cars isnt so easy like the 04 and older cars.... Old cars= slow processors, so SD was the way. New cars=fast processors, MAF is the way Card maf in a 4" tube is good for 800 on a blower car. Smaller tube=less HP before its maxed out. 75mm MAF= maxed out at 500
Good luck John!!
Good luck John!!
Good luck John!!
Good luck John!!
Good luck bro-I might be putting a F1R depending on your results.
We'll see you at the mile as well this year!
It's always something. The LS2 intake bolts do not work on LS7 intakes and the 3/8 pushrods rubbed the heads, so we had to order 5/16. Hopefully it will run next week.
I have not had the car in 7 months. One more week won't kill me.
