What makes the trim? Superchagers
Old 06-07-2009, 08:55 AM
Anthony0908's Avatar
Default What makes the trim? Superchagers
I have a Vortech V1 head unit/ No comperssor wheel.
What makes the trim of the head unit. EI: A trim S trim t trim? The impeller, compressor wheel?
Where can I buy a compressor wheel for a Vortech V1 and a rebuild kit. Im not sure if it needs a rebuild but i might as well do it before it does need it.
Old 06-07-2009, 07:41 PM
No one knows were to buy impellers?
Old 06-08-2009, 12:29 AM
DeltaT's Avatar
Check your other post - I gave you someplace to try. Typically it is a combo of the wheel and volute (scroll housing) that defines the trim for a Vortech.
If the other contact can't help, Vortech may be your only source, and IIRC they will not sell you the parts, they will only rebuild the unit for you for $$$.
Jim
Old 06-08-2009, 01:02 AM
Jim
Thanks because your help I located one .
On all the v1 in the pics the outside housing is the same.
Only when you go to a v345678 do the outside housings change
Old 06-08-2009, 09:59 PM
DeltaT's Avatar
No, the V-1/V-2 S and SC-trim housings are the same, but the E-trim and T-trim are each different. They might be the same casting but use a different mold insert to end up at different final dimensions.
Be careful or you might end up with non-working junk.
Jim
Quick Reply: What makes the trim? Superchagers
