Boost and FPR???
Old 06-07-2009, 06:28 PM
mk1973's Avatar
Default Boost and FPR???
I am running a stock motor LT1 with an STS rear mount kit, the kit makes 6psi of boost. the problem I'm having is the the stock FPR is supoosed to max at 43.5 psi. under boost i'm seeing 46-48 psi and it's throwing off my tune.
I was thinking of using a vacuum check valveon the vac line going to the FPR. what do you guys think???
Old 06-07-2009, 08:09 PM
stevieturbo's Avatar
That makes no sense. How is the FPR suppsoed to max at 43.5 ?
and 4psi of fuel pressure wont make much difference.
Old 06-07-2009, 08:54 PM
mk1973's Avatar
The reason I ask, is because the guy tuning my car said that was throwing off the wot tune boost starts at 3000 I'm at 12.00 on WB by 3500 I'm at 10.20. Any ideas?
Old 06-07-2009, 11:29 PM
a new tuner ?
