HELP! - 6 psi Blowing off Silicone Connector
My STS kit makes anywhere from 5.5 psi to 10 psi (depending on my boost controller's setting), and it uses a 2.5" to 3" silicone connector just in front of the MAF; but it keeps blowing the connector off!
I've tried double hose clamps at both ends, in addition to 3M Mastic Tape, but every time the turbo hits 6 psi, the pressure blows at the MAF.
I'm sure I can't be the only guy who's had this problem - what is the best way to resolve this problem? A new silicone connector? Duct Tape? Super glue?
HELP!
HELP!
HELP!
HELP!
Make sure eveything is clean. Wipe down with denatured alcohol. Also check your motor mounts. Make sure you dont have to much movement pulling the hose off.
I run beaded boost tubes, regular old 3 ply straight silicone hose, and good T bolt clamps with boost pushing 60psi on the truck pictured in my sig with no issues.
To add to this if your tubes are polished or very smooth rough them up with scotch brite than clean and glue. The rougher surface give the glue more purchase.
If the tube you are trying to clamp to is really smooth or chrome, none of the above tricks might do it reliably. You really need a lip, flare or bead on the end of what you are clamping to so the T-bar clamp has a mechanical stop to work with.
Any pics of what you are trying to clamp to?
Jim
Jim
Jim
Jim
If you can't get them flared, then welding a bead on works but wrapping aluminum wire around the pipe and tacking in place is quick and resembles a flare better than building up a bead to accomplish the same thing. If you are are paying by the hour for welding - a lot cheaper too.
I have never blown off a hose.
Jim
Thanks for all the suggestions guys!
The black silicone and standard hose clamps (torqued with a 1/4 drive ratchet vs. a 5/16 nut driver!) has held up to 11 psi according to my #1 son, who was in the pass seat reading the boost gauge, as we jumped on the freeway today!
Too much fun!
Now off to get a real Dyno tune, as my mail order tune is close but (IMHO) far too rich!
Too much fun!
The stainless T-Bolt clamps are what you want to eventually use.
They are pretty hard to break, do not slip, and for sure don't eat into the silicone hose like screw type hose clamps do.
They are much cheaper now than what they used to cost. At 11 lbs of boost I would want to play on the safe side and make sure than they will never come loose. You don't want to be sucking dirt into your intercooler(s), blower, or engine if one comes loose.
Check your system frequently as there is a lot of movement and flexing, engine, frame, heat expansion and contraction.
