Oh...SNAP!!!
Old 06-14-2009, 04:18 PM
Fireball's Avatar
Wink Oh...SNAP!!!
ran our local drag radial event at Maryland International Raceway Friday night.
1st qualifier...back down the tune to ensure the car gets down the track and we make the field
5.310 @ 142.72
2nd qualifier...more boost at launch and more boost up top
something broke at the top of 1st gear
tore it apart Sat morning
opps...found this sitting in my torque converter
manufacturer is taking care of it and replacing it since there was a known heat treat issue from that batch of input shafts. while its apart we decided to have the converter tightened a few hundred more rpm
so I had to go and do this to ensure I can build boost properly on the line
here are the vids of the runs
http://home.comcast.net/~tfranklin55...runs_small.wmv
Old 06-14-2009, 04:45 PM
bgblockelcamino's Avatar
dam. congrats. keep dialing it in and you will have your 7s in no time
Old 06-14-2009, 05:40 PM
Restricted User
98Z28CobraKiller's Avatar
What type of rear suspension setup do you run?
What was it stalling at? Are you restalling to tighten up on the long end (slip)?
Old 06-14-2009, 05:49 PM
Fireball's Avatar
Originally Posted by 98Z28CobraKiller
What type of rear suspension setup do you run?What was it stalling at? Are you restalling to tighten up on the long end (slip)?
stock replacement stuff out back Performance Auto Fab torque arm, heavy duty rear swaybar, and Panhard rodWolfe LCAsAfco double adjustable shocks (coil over)stall speed is a
yes...tightening up to increase efficiency through the middle and bigend of the track...
Old 06-14-2009, 05:51 PM
biggdogg's Avatar
that was the first thing i had to do to mine also was the dual brakes you will like staging alot better...
Old 06-14-2009, 05:54 PM
Fireball's Avatar
I could hold 3900 rpm threestep on the footbrake but staging is definately touchy Probably will be that much harder with a tighter converter
Old 06-14-2009, 10:24 PM
NA$TY-TA's Avatar
Damn Brian... saw this over on bullet.... track was hooking nice huh??
What were the 60's like??
Old 06-14-2009, 10:27 PM
elias_799's Avatar
congrats. love the brakes
Old 06-15-2009, 06:48 AM
Fireball's Avatar
1.36 IIRC
last run was wierd...had more boost tuned in and it only went 1.40 but it didn't spin...was marching down the track until it broke though
Old 06-16-2009, 06:25 AM
Navy David SS's Avatar
Nice run! Looks like both runs were smooth. 142 in the 1/8 is getting it done. What size of axels are you running?
Old 06-16-2009, 06:35 AM
Fireball's Avatar
35 spline...but that pic isn't an axle
Hint...said I found it in the torque converter
Old 06-16-2009, 09:03 AM
TrakDay's Avatar
This makes me wanna get my car back together that much faster now.
Good Luck man...
