Angle of hot pipe into turbine housing?
Old 06-16-2009, 08:34 PM
2nd Gen Fl 'bird's Avatar
Default Angle of hot pipe into turbine housing?
Has anybody done any kind of research on this? Is a straight shot into housing the best for spool up? Or, is heat and pressure just that and the angle of the charge is insignificant? Or maybe I should quit thinking too much. Gotta look at every angle, as minute as it may seem,for the ET.
Old 06-19-2009, 12:14 AM
ModularTurbo's Avatar
Using a LIL' common sense can go along way. If it looks restrictive it is...
Quick Reply: Angle of hot pipe into turbine housing?
