how much can i expect to see?
Old 06-16-2009, 10:59 PM
F-BodyGuy98's Avatar
Default how much can i expect to see?
hey guys, im going to be picking up a 6.0l truck motor pretty soon i hope, im going to be using the block of course, the crank and the heads off of it, as ive read that the stock crank and heads can hold up to a substantial amout of abuse. im still looking into what pistons and rods to go with, i know i need pistons that will give me a nice low compression ratio, im only going to be going .030 over on the block just to clean up the cyl. walls a bit, and having the heads slightly ported, again just to clean up the runners a bit, im going to use the edlebrock victor jr, intake with the 90* elbow, and the EPP forced induction cam, and im moving the turbo set up to the front...im just curious as to how much power i can expect to see if any one has an idea, im hoping for 700rwhp, but anywere in the mid to high 6's will do. thank's
Old 06-16-2009, 11:31 PM
'Trust''s Avatar
Depends on how much you weigh, my car only goes 6.3's right now due to the weight.
Old 06-16-2009, 11:33 PM
sorry, should have phrased it better, i meant im looking to see 700rwhp, but ill be happy if i see some were from the mid to high 600 rwhp range..
Old 06-17-2009, 03:21 AM
vff_jeff's Avatar
what turbo, and how much boost? 700whp is probably like 18-20psi??? I have friends running in the 600whp with a 6.0 but they have like 14-16psi.
Old 06-17-2009, 08:54 AM
Grr
Grr's Avatar
I ran a stock longblock LQ4 with a 224/283-112-.565" cam, a S475, at 14psi it put out ~625whp. I took it up to 16psi a couple of times and it picked up 4-6mph so that had to have been ~675whp, just fyi
Old 06-17-2009, 09:25 AM
Sluggish's Avatar
I went 6.84 making 530rwhp on a mustang dyno 3650 race weight.
Old 06-17-2009, 07:15 PM
its going to be a TC-76 and on low im planning on running anywere from 10-12psi and high im looking to be running about 20psi
Old 06-17-2009, 09:31 PM
black98ws6ta's Avatar
I would think the tc 76 might run out of breath before 20 psi but there is only one way to find out. It should not have any problem making 700rwhp.
Old 06-17-2009, 10:10 PM
i like the sound of that, lol, being thats its not my DD any more, i can chance it..haha
Quick Reply: how much can i expect to see?
