Rule 3700 pump part 2.
Old 06-20-2009, 02:13 PM
Coal Mining Director
onfire's Avatar
Default Rule 3700 pump part 2.
5055 ft density altitude. 94F....hot,hot,hot...good day to test the Atw pump.
Only made one run since the track temp was 123F and nasty out...but wanted some data.
2 gallons of h2o plus 32 lbs of ice...that was melting fast in the pits...lol..
IC core was around 100F when I turned the pump on....dropped to 63F fast...during the burnout. Left the line at 63F and finished the run at 94F. 19psi 153mph....4025lbs...decent results for the IC...should have run the pump longer before I made the run.
Old 06-20-2009, 03:31 PM
7 Second Club
Phil99vette's Avatar
did you pre-cool the core before you ran? Can you give a detailed run down of the setup?
Old 06-20-2009, 04:12 PM
onfire's Avatar
Twin 76 Turbonetics 81ar, Speed inc kit. 428 ci, 19psi, 15degrees timing that will now change with the AtW, Garrett 2000hp core, 3.00 rear gear, 325's, tight NC converter...93% up top, leave at 3900 on 7-9psi...7psi = 1.5x sixty, 9psi =1.42sixty, now 4025lbs....still has AC, power everything...heavy goof build.
Turned the pump on at the burnout when the core was 100F...dropped to 63F by the time I came off the brake....only "prechill" was in the burnout box.
9psi launch here:
http://videos.streetfire.net/video/B...run_683589.htm
Old 06-20-2009, 04:28 PM
7 Second Club
Standard or high density IC core?
What size lines to your IC?
Fuel type?
I run the pump in the pits until the IC sweats.
Old 06-20-2009, 04:35 PM
onfire's Avatar
http://www.turbobygarrett.com/turbob...tercoolers.htm
Two of the 734408-6005 cores welded together.
1" lines 38ft long.
Sunoco 116
Precooling down into the 40's should really help.
Then comes the debate of AIT's vs Octane...some will argue 100F is better for 116.
Old 06-20-2009, 04:38 PM
7 Second Club
I'd use 1.25" lines
You need to add 6-9 degrees of timing
Pre-cooling would definitely help
Old 06-20-2009, 06:04 PM
kp
kp's Avatar
You are pretty hardcore, only place I'd be on a day like today is inside with the air conditioning on
Old 06-20-2009, 06:48 PM
onfire's Avatar
It was 6:15 yesterday....and I should have been inside exactly like you say....had to make one hit to see if all the hacking was worth it. Nothing more fun than an asphalt pit on a 94 day with a firesuit on.
Old 06-20-2009, 06:49 PM
onfire's Avatar
Originally Posted by Phil99vette
I'd use 1.25" lines
What AIT's are you getting on the brake and at the end?
Old 06-20-2009, 06:51 PM
onfire's Avatar
BTW, 1.25" lines are worthless unless the core has 1.25" inlets/outlets...
Old 06-20-2009, 07:00 PM
7 Second Club
Who made it?
Quick Reply: Rule 3700 pump part 2.
