What size pushrod to buy for boosted 427 with TFS245 heads
Ok getting closer to finishing my 427 motor It will have TFS 245 heads and terra yella rockers with morrel lifters. What size push rods should i put in this motor. Will be seeing about 15 psi of boost at first then later 20ish
Not length cause i will be checking that, but the thickness and type?
How long does it take to get pushrods ? I might need them to be ordered to a custom length so i can set the preload of the lifters if its not a stock size.
Ok sound good i was worried about oil pooling in the head cause of my MEL10296 oil pump
So going to order Manton pushrods that are 3/8 but how do i order them with a oil restrictors? Are all oil restrictors in pushrods the same ?
