smallest procharger 8 rib pulley?
i have a 3.70 now and making 11-12 lbs.(@7,000rpm) want to make 17lbs. possible?
im thinking i would need a pulley around or just under 3". do they make them? is there a setup that uses a bigger crank pulley? mine is 7.25 now...
searched but came up wit nothing!
8 sec potential, 12 sec slip
Are you running the SDCE kit? If so, I think you are limited to 7.25. The stock procharger 8 rib crank pulley is 7.65". And to answer the original question, the smallest blower pulley I've ever heard of is 3.2", but there may be smaller ones. I would think 3.2" is just begging for belt slip tho!
i have the same set up... i did go with a bigger crank balancer innovators west great belt wrap no slip...have a 4:00 8 rib pulley on it making 14p-15 pounds of boost...by the way if you are changing your pulley and want to sell the 3:70 let me know..
soooo i think id need somewhere in the neighborhood of 7.75" cranck pulley. and im not goingthrough those innovatorswest.com guys for a custom. thats crack prices.
just looked into it a lil further. i dont need the entire pulley that slides on to the crank. i have an ati damper so i just need just the pulley that bolts onto the face of the damper. my original setup is an sdce.
