Drilling holes in MLS head gaskets ?
Old 06-26-2009, 04:13 PM
BigRich954RR's Avatar
Default Drilling holes in MLS head gaskets ?
Was about to put my heads on and the gaskets doesn't fit on the outer head studs. I say the holes are 1/16 to small to fit over studs
Do i drill the outthe holes bigger ?
How Do i drill the MLS head gaskets with bigger holes?
Old 06-26-2009, 04:31 PM
BadgeZ28's Avatar
Try pulling a couple studs, installing the gasket and then see if you can refit the studs without any drilling. My guess is there is just enough bowing in the studs to cause this.
Old 06-26-2009, 04:34 PM
Its only in the shorter extra bolts on the warhawk block on the Exhaust side
Quick Reply: Drilling holes in MLS head gaskets ?
