New to F1 section need injector help
Hey everyone, I just purchased a p1sc procharger kit for my 2001 camaro ss. So I will be frequenting this section a lot more while I get every thing pieced together. Would a 42lb injector be enough to run 8 psi? along with a new fuel pump and I dont know which pump to get
Ok ill either be going with the 50's or perhaps 60 injectors and a walbro 255/racetronix pupmp and the racetronix hot wire kit. What brand is more popular for ls1 engine? How do you move the fuel regulator?and would it be a have to do kinda thing?
I run 7psi with 42's and I am at 98% duty cycle. I have the nasty stage one kit with the racetronix pnp pump. Depending on what the rest of your mods are will be the deciding factor. If I had to do it again 60's would be a better choice for me, but I am cammed, full exhaust etc..
Save yourself the hassle later on, and go with the 60's. SD 60's are plentiful and support great power. The single 255 will be fine, but an extra would be safe insurance should you decide to up the boost down the road. I know you say you probably won't, but you will have that opportunity without having to drop the tank a second time.
