Procharger BPV problem?
Old 06-29-2009, 08:40 PM
02NBMFormula's Avatar
Default Procharger BPV problem?
I went to the track last weekend and at the end of the day, i noticed that the bpv seemed to be going off all the time. I got it back from the track and noticed that it chirps whenever i let off the gas (1/4, 1/2, 3/4 and full throttle) regardless of being in boost. its also holding 10 inches of vacuum steady, even when i let off the gas at 4k rpm. it will hit about 8.5-9 psi (usually around 10-11). i pulled off the bpv and couldnt visually see anything wrong with it. also couldnt find any boost leaks. whats going on here?
Old 06-29-2009, 09:19 PM
jomomma's Avatar
i knew mine was too small when it was shrieking when i let off after wot. i was making about 12lbs then. if you want to try another proflow, you can get mine. i went with the race bypass. just send me an offer.
Old 06-30-2009, 04:58 AM
EPP
EPP's Avatar
Where are you picking up your vacuum? More than likely you have it tied into the brake booster vac, we have found less chirping by tying in into the hvac line on the passenger side of the firewall. Bob
Old 06-30-2009, 11:03 AM
found the problem, the adjustment screw on top of the bpv is missing. how that happened, i dont know.
Quick Reply: Procharger BPV problem?
