Solid motor mount and rubber tranny mount question
Old 07-01-2009, 09:31 PM
maxgee's Avatar
Default Solid motor mount and rubber tranny mount question
i hear running solid motor mounts and rubber tranny mount is not good. what about running one solid motor mount and keeping the rubber tranny mount?
reason, i want to running downpipe from my turbo over the crossmember and with a solid mount i will have the space.
i have been getting away with it under, but i have the motor out now and putting in another and figured to do it now, rather than later.
Old 07-01-2009, 10:12 PM
pwrtrip75's Avatar
Thats BS. whoever told you that is an idiot. I have had solid engine mounts and a rubber trans mount for like 12 years now.
Old 07-01-2009, 10:36 PM
tkimrey's Avatar
Agreed...I don't know who comes up with this stuff. Think about it, if you're running solid motor mounts it's not moving at all (it's solid), so why would a rubber tranny mount be hurting anything. I know it made my car feel like it was shifting so much smoother.
Oh, I've been running solid mounts with a stock tranny mount for 2 years and not one single issue at all.
Old 07-01-2009, 11:02 PM
93formto98T/A's Avatar
Ditto. I'm also running solids with a rubber tranny mount. It's actually recommended- if you run solid motor mts and solid tranny mount and get some chassis flex coming off the line, you can actually break the tranny if it torques enough. Running a motor plate is another story-all solid is ok including a solid mid tranny mount.
Old 07-02-2009, 06:31 AM
maxgee's Avatar
thank you gentlemen,
there are plenty of post saying the opposite, but i agree with you guys, i can't see how it could hurt.
thanks
Old 07-02-2009, 09:46 AM
MY99TAWS6's Avatar
I would think if torque arm is still on the tranny it would rip the rubber mount even if you have solid or poly motor mounts. I have poly motor mounts. I have rubber trans mount and my torque arm is on my trans for another month or so. Then might go poly trans or might stay rubber since the arm will be on crossmember and with poly mounts or solid and arm off cant see how it could rip the stock mount. And stock mounts are quieter usually.
Old 07-02-2009, 04:12 PM
OUTLAWZ RACING's Avatar
I agree with the shifting smoother. I have solid motor mounts and a enegery trannie mount on a umi tourq arm. I will say this shifting at 7k was a problem because I had to shift slow but now hell it has no problem going in.
Old 07-03-2009, 02:54 AM
That's what she said...
TheBlurLS1's Avatar
The problem is when you try to run poly/rubber motor mounts and a solid TRANS mount. Motor twists, trans doesn't = broken trans lol.
Old 07-03-2009, 03:47 AM
TheBlackPlague's Avatar
I run solid motor and rubber trany on my DD and i wouldnt have it any other way.
Old 07-03-2009, 04:29 AM
stevieturbo's Avatar
As above...solid motor mounts and rubber tranny for a few years now. Works fine for me ( no torque arm on my car )
Old 07-03-2009, 12:36 PM
Big_Bird_WS6's Avatar
no torque arm?
wth
Old 07-03-2009, 12:38 PM
Think about it... Does every car use a torque arm ?
Old 07-03-2009, 01:32 PM
i saw video. good point.
Old 07-03-2009, 01:44 PM
maxgee's Avatar
Thanks going solid motor mounts and keeping my rubber tranny mount.
Quick Reply: Solid motor mount and rubber tranny mount question
