where is the ideal place to measure boost?
Old 07-02-2009, 11:44 PM
cals400ex's Avatar
Default where is the ideal place to measure boost?
i think some of the guages tap into the stock map sensor to read boost. is this an ideal place? i didn't know if that is where you were supposed to measure boost or not??
Old 07-03-2009, 04:36 AM
stevieturbo's Avatar
The only place is the intake manifold.
Old 07-03-2009, 07:00 AM
conan's Avatar
I have all my vacume equipment pulling from the brake booster line.
Old 07-03-2009, 07:42 AM
Dumb Ass Vette Moderator
ls1290's Avatar
Totally agree. I have my boost gauged Y'ed into the location where my MAP sensor is since I have a SD tune.
Old 07-03-2009, 09:23 AM
cals400ex's Avatar
i guess i didn't know if there would be a difference at the front or the back of the intake. thanks for the help.
Old 07-03-2009, 11:27 AM
stangbangin69's Avatar
i was told, by my tuner, that the reading should be taken from the rear of the manifold. if it is taken from the front then the engine hasn't had the chance to "gobble up" the boost. the reading won't be a "true" reading of psi. i trust him.
brake booster hose would be an ideal place.
Old 07-03-2009, 12:00 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
I dont think the brake booster is a good place at all. Infact, I think its a bad place, but thats just my opinion i suppose.. Anywhere on the manifold should be the same.
Old 07-04-2009, 09:23 AM
1320's Avatar
I run small vacuum block. I port things off it, like the brake booster line, the lines for things like boost controllers, bov's, alky controllers etc....the last thing in the block is the boost gauge. If you get a leak anywhere in front of the boost gauge, its easier to see on the gauge. Sometimes a small change in the vacuum reading or boost responce or peak boost can indicate a possible leak somewhere. The more things you run, the more avaiable volum you need from the feed line and the block. The more volume you have the more sensitive the gauge the will be. The numbers dont change justthe way it responds to changes.
Old 07-04-2009, 11:29 AM
What a load of *****.
Its quite common on many cars for there to be a takeoff mounted on the TB itself. Location on intake manifold itself is pretty irrelevant, as loing as its thereabouts.
Nothing particularly wrong with teeing into the booster line either though, it is after all attached to the intake manifold.
Old 07-05-2009, 04:11 PM
okay then...
why is it that when i hook my boost gauge up, at the front of my intake, it reads 11psi. then when i move it back to my brake boost line "t" it shows 6.5psi? someone care to chime in with an explanation on this one?
Old 07-05-2009, 04:33 PM
You must have a leak somewhere on the brake booster line.
There can be no other possible explanation.
Old 07-05-2009, 05:22 PM
i'll have to investigate the leak.
bottom line is that we both agree that the brake booster hose is sufficient enough for an accurate boost reading. just do it!
Old 07-05-2009, 06:48 PM
ChevyChad's Avatar
I wouldnt want to take any vacuum away from, or even create potential for leaks there on a part of your car as crucial as your brakes. Just my opinion, but I'd tap into any other source on the manifold other than the brake booster. Your car tho man, if you feel comfortable with it, have at it.
Old 07-05-2009, 10:31 PM
1320's Avatar
I would guess a leak in the line somewhere between the intake and the t that your using to hook the gauge too.
