wantin a bigger motor for my turbo build
Old 07-05-2009, 06:59 PM
HillbillDeluxeSS's Avatar
Default wantin a bigger motor for my turbo build
i was gettin ready to start a turbo build and im tryin to figure out how big of a motor to build...id like a 400"+ with a 76mm turbo...what can u punch a 346 ls1 out to? without goin TOO far
Old 07-06-2009, 07:16 AM
smokinHawk's Avatar
can only go .010" max on an aluminum ls1 (preferably only .005), could use a 4" crank to get to around a 370
which i wouldnt go bigger with that small of a turbo.
Old 07-06-2009, 08:41 AM
Restricted User
98Z28CobraKiller's Avatar
3.905 bore and 4.0 stroke = 38Xci
As stated, not gonna want to go any bigger than that with a 76mm turbo.
If you must stroke it, go to a 3.9 stroke so that you end up square. This will get you into the 370's ci and wont burn as much oil. Stock cubes will be ideal for the 76mm though.
Old 07-06-2009, 08:55 AM
ls 2 goat's Avatar
You can sleeve it and go up to a 427 (4 inch stroke, 4.125 bore). Add a deck plate and it gets even crazier. Take a look at ERL performance.
Old 07-06-2009, 08:58 AM
Restricted User
Would be cheaper to just buy an LS7 block if you want to go that route but he is using a 76mm turbo so that's really not even a concern at this point.
Old 07-06-2009, 09:24 AM
ls 2 goat's Avatar
Yup. I would stay around a 370 to 38X if it were me.
Old 07-06-2009, 09:38 AM
B18CYA's Avatar
Your gonna make just as much if not more power with a t4 76 on a 346, plus you want have to spend for a crank or punch the sleeves out to nothin. How much power are you tryin to make?? People are making huge power around here with 346 tc76/78 combo's just my 02
Old 07-06-2009, 05:17 PM
well maybe id need a bigger turbo to...i had a lq9 block but i sold it...i may get another one...with adding stronger internal parts and good heads and cam with a bigger turbo, would i get good results too? i want a nasty car on the strip..thanks for all the help guys
Old 07-06-2009, 11:04 PM
vogun16's Avatar
alot of people on here are putting over 500rwhp down with stock motor stock internals and a t76, just dont know how long it will last haha
Old 07-13-2009, 09:00 AM
ERL Performance's Avatar
We have LS1, LS2's in stock sleeved already and have packages available from 427 CI all the way up to 500 CI and everything in-between. Let me know if we can help with your build. Thanks!
Old 07-13-2009, 11:37 AM
MelScrilla's Avatar
i always liked the 370 LQ4 with the 80 or 88mm
Old 07-13-2009, 03:57 PM
Restricted User
What are you guys getting for a superdeck1 with 6 bolts and a 4" bore? Bare block with main caps.
Quick Reply: wantin a bigger motor for my turbo build
