Solid motor mount custom exhaust manifolds??
Hi there guys
My build with 94mm turbocharger and LSX block is getting close to end... When I first searched about motor mounts at the beginning of this project, I decided to use the stock ones as my future K-member might not be suitable with the solid motor mounts. However, now I am planning to stick with my oem k-member as by builder is doing piping accordingly, so now I am thinking about getting some solid motor mounts and poly trans mount.
The problem is, after searching, I found out that Spohn solid motor mounts raise the engine a lot. This might be a problem for me as my exhaust manifolds are custom made and the dimensions are according to original engine sitting height.
My question is how much exactly do the Spohns lift the engine with stock k-member? Is there any other solid mount manufacturer that has the same height as the stock mounts??
Thanks for the help.
Here is my engine and manifolds...
any mount you use to replace the old stockers will raise the engine back to where it needs to be height wise. the old mounts rubber is old and starts to sag and let the engine fall. when i replaced mine back in the day with solids it brought my engine up 1/4 of a inch up
Have you used solid motor mounts?? Which one?
Or should I just go with UMI Road race k-member that has its own solid motor mounts on it. How much would it raise the engine?? I am not sure if UMI k-member can withstand the stress coming from my 427 lsx block, 94mm turbo and stainles steel intercooler piping and headers. Car's nose will be much heavier than stock after all is finished...
