2 step question
2 step question
For a Manual Car:
1. What do you retard the timing too with the 2 step engaged?
2. What AFR do you target with the 2 step engaged?
bit off topic but the WRC cars used to retard the timing SO much that even at WOT and with 15psi boost with no load (out of gear) they would still hold the rpm back to about 5-6Krpm! pretty bonkers! lol
Thanks for all the feedback (no sarcasm intended) but does anyone have an answer to the two original questions?
For a Manual Car:
1. What do you retard the timing too with the 2 step engaged (or what have you found to work well)?
2. What AFR do you target with the 2 step engaged (is approximately 11.5:1 what others target)?
For a Manual Car:
For a Manual Car:
For a Manual Car:
for the AFR i would not worry about it because its going to go rich as hell do to the spark being cut out
but you need to start low and work your way up and see what works best for you man go have fun with it thats my 2cents
Restricted User
Yeah, I run a RMVB TH350 with tbrake and about a 4500 stall from FTI. It currently has a 3.73 gear but due to the lowering of my rev limiter to 6500, I'm out of gear by about the 1200'-1250' mark. I have done pretty much all the suspension mods. The chassis had a 408ci + 380 shot and has been 9.33 @ 146. I didn't (still don't) have the money to forge the bottom end and throw my heads on it after blowing up my old setup. I decided to throw in a cheap stock iron LQ9 long block and get the turbo kit all fabbed up so I could get back on the road.
As far as timing is concerned, I figured that it might last a little longer at 13* seeing as though I am hitting it with 15-16#'s on 93 octane.
