Boost level, air filter vs no air filter
Old 07-15-2009, 08:31 AM
rufretic's Avatar
Default Boost level, air filter vs no air filter
I'm making a little more boost than I would like to with my F2 at 26psi. Right now the inlet is wide open. How much do you think adding a 4" 90 with a big air filter will lower the boost? I know some people have used a retrictor plate on the blower inlet to limit boost so I figure adding a filter should restrict it some in the same way, I just have no idea how much. I'd like to get it down to around 20psi. I know I can swap pulleys but I'm planning to add the filter anyway so I don't want to start messing with pulleys unless I have to. Any ideas on how much boost might be lost with the air filter?
Old 07-15-2009, 09:32 AM
AFASTYZFR1's Avatar
I don't have an F2 so I have no idea how much it will limit your boost, but it you are going to run it on the street a lot you might as well throw a filter on it and see what happens. Then you can re-pulley it if necessary.
But a 4" 90 with a large filter probably won't limit it much
Old 07-15-2009, 09:33 AM
nastychevelle's Avatar
if your planning on doing it anyway just do it and let us know and then swap pulleys if it doesn't lower it enough
Old 07-15-2009, 09:49 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,089 Likes on 717 Posts
You should run a filter anyway so go get it and see what it does. I fugged up my blower from ingesting crap, that's why my blower went from being a YS to a YSi.
Old 07-15-2009, 06:00 PM
gametech's Avatar
If just a filter doesn't do the trick, you could also use one of those filter socks for added restriction.
Old 07-15-2009, 09:41 PM
rufretic's Avatar
Thanks for the responces guys. I thought maybe someone would have a back to back with and without the filter to give me an idea on how many psi I might lose. I'm guessing only about 2psi but I guess I'll just try and fit one on and see what it does.
Old 07-15-2009, 09:45 PM
rufretic's Avatar
How many miles did you run it without the filter to cause that? I didn't think it would be that big of a deal since I only put about 500-1000 miles on the car a year. Now I'm going to put the filter on for sure just for that alone.
Old 07-15-2009, 09:55 PM
'Trust''s Avatar
I picked up 3.5 PSI with no airfilter.
Old 07-15-2009, 10:05 PM
rufretic's Avatar
Wow, that's a pretty good amount. Maybe the air filter will get me to where I want to be.
Old 07-16-2009, 12:53 AM
WAHUSKER's Avatar
I didn't monitor the boost change but I picked up 35rwhp by removing my 90* elbow & large cone filter on my F1 at 14 psi so it should "help" to add one....
Old 07-16-2009, 06:25 AM
Dumb Ass Vette Moderator
ls1290's Avatar
A restriction plate is a well proven concept for limiting the amount of boost.
Quick Reply: Boost level, air filter vs no air filter
