I Know I Know, Not Another Ebay build!
Old 07-19-2009, 11:23 AM
Dean95z28's Avatar
Default I Know I Know, Not Another Ebay build!
Well yes another ebay build. I wasn't going to post but I am excited and pretty proud of what i have accomplished. I have been working on my car for about 8 months. Never intended on going as in depth on the build, but it is finally about done and going on the dyno on the 25th. Its funny how the build started all becouse of a grenaded 10 bolt! Pulled the rear end out and proceeded to tear the rest of the car down.
Here is a list of Mods:
Lq4, 317 heads
ARP head studs and rod bolts
ported oil pump
double roller timing chain
03 ZO6 cam
Vic Jr, Elbow, and TB
Aeromotive A1000, Boost referenced FPR
-10 feed, -6 return
60lb mototrons
Ebay PTK kit
Modular Turbo hooked me up with the Turbonetics MC78 (TC78)
JGS 40mm wastegate, and 56mm BOV
Ebay intercooler
Custom cold piping
Th400 3600 stall
Adjustable LCA's, Panhard, and UMI torque arm
Here are some pics.
Old 07-19-2009, 11:42 AM
Texas_WS6's Avatar
Sweet! I started my rear mount DIY with the GT-88 before I saw that ebay kit. If I wasn't so far into what I have I would have bought that kit. I wish I would have. The only thing I did not like about that kit was the wires on the drivers side look real close. Nothing that some good header wrap and heat sheilding could not fix.
I like what you did with the radiator and its support. Do you still have the AC in this car? Will the AC condensor still fit infront of your radiator? Do you have a part number on that radiator that you can share? I am running that same Edelbrock elbow, I am not sure that I like it. I am pretty sure it is causing a major restriction on my engine, like 100hp NA restriction. NA my engine is down about 100-150hp from expected. I am hoping it will not matter with the turbo.
Keep us posted, I am actually going out into the garage to pull my front end off so I can start installing my intercooler like yours. I have the hot side finished and I have run the cold side from the rear mount up to the middle of the car.
Great job! Keep us posted and put more pics of your build up please.
Old 07-19-2009, 11:50 AM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
Bonus points for the driveway buildup!
Old 07-19-2009, 11:52 AM
Texas_WS6's Avatar
Thats the only way to do it, at home in the garage and driveway. That way the neighbores know whe are crazy!!!
Old 07-19-2009, 11:54 AM
Dean95z28's Avatar
No ac in the car anymore, Im not sure if the condensor would fit or not. The radiator is a griffin GRI-1-25241-X. I got mine from Summit for about $200.
I started the car for the first time last monday, everything seems to be working great so far. I have put about 50 or 60 miles on it so far. I will post some more recent pics up later.
Old 07-19-2009, 11:57 AM
Dean95z28's Avatar
Yeah driveway builds are great. Well except for the winter part of it!! I have great neighbors, not a word was said.
Old 07-19-2009, 02:42 PM
98Camarod's Avatar
I'd like to see your dyno numbers and track times. You have more cubes and a larger turbo, but I'd still like to know. What kind of boost are you going to be running? Does that single fan keep it cool? I ended up going with the Taurus fan to finally keep my car cool. I'd like to get my cold side redone, but I don't have a welder. It looks good, but what rear did you end up going with
Old 07-19-2009, 03:18 PM
Dean95z28's Avatar
I have 2 fans and they are border line on keeping my car cool. I know i am going to have to replace them. Also I have moddest HP hopes of 550 wheel! I think it should do it on 10lbs of boost. We will see next saturday.
98camarod, What fan setup did you use? Taurus? Where can I look at these?
Old 07-19-2009, 03:23 PM
98Camarod's Avatar
Its the fan from a box body 3.8l Taurus. I got mine off of, you guessed it, ebay. It keeps it under 190* in the SC heat. That is what I figured I was making was around 550rwhp, but you do have the th400 so that's going to "eat up" some power.
What rear did you end up going with?
Old 07-19-2009, 04:40 PM
Dean95z28's Avatar
Im on a stock rear end with a 2.73 gear, and I will also be on a 28 inch tire!!!! Probably won't last long, I just don't have the funds for a 12 bolt right now!
Old 07-19-2009, 04:45 PM
98Camarod's Avatar
lol, you probably would if it didn't go else where. I recently put in a 9". I thought about the 12 bolt, but after researching I found the 9" to be the better decision.
Old 07-19-2009, 04:50 PM
Dean95z28's Avatar
Well I figured after watching a few corvettes live on there rearends on boost above 10lbs running in the mid 10's or faster. I should be ok as long as I keep my 60's soft.
Old 07-19-2009, 05:23 PM
98Camarod's Avatar
Do you have any pics of it finished? I'm curious to see how the cold pipes are ran
Old 07-20-2009, 08:42 AM
Phat69's Avatar
I've read that elbow will cause the front cylenders to starve for air flow might wanna watch the plugs closely.
Old 07-20-2009, 08:51 AM
Texas_WS6's Avatar
Yah, I have been continplating this. I am thinking of changing the entire intake out. I am just not sure what will work best with the FI and not require cutting on the car. Any advice?
Old 07-20-2009, 10:34 AM
2Tightwads's Avatar
Swap you my LS6 intake? Can't go wrong there...(This is CK from Hp Tuners) Doing some trolling around here and started following your old posts. Looking forward to your completed build!
Old 07-20-2009, 10:46 AM
Texas_WS6's Avatar
Hey CK! The LS6 intake will not fit my L92 heads. I am thinking of a sheet metal intake. I am looking into buying a tig and building one myself. Who knows, I might start selling them if it works out right.
Old 07-20-2009, 10:50 AM
2Tightwads's Avatar
Yah I just logged back in to tell you sorry can't do that...DUH! Lol Anyhow I'm watching and waiting!
Old 07-25-2009, 09:56 AM
6L.IROC-Z's Avatar
Good job on the build Deano. Your setup looks clean and sounded badass coming by me the other night.
Old 07-25-2009, 10:59 AM
dudeman's Avatar
what did it dyno?
Quick Reply: I Know I Know, Not Another Ebay build!
