Blew stock 346 with STS need help where to go from here? 383? 402?
Old 07-19-2009, 08:01 PM
vipvegas's Avatar
Default Blew stock 346 with STS need help where to go from here? 383? 402?
Well I have the engine out cylinder 8 is fried. I have an 01 WS6 with STS t67 fmic. I have $3000 to 3500 max to spend on build. What is the best way to go for almost daily driver wanting to run 10-12#'s boost. Also whats safe boost and hp on applications advised? Should I go forged 383 or 402? Any help from sponsers would be appreciated as Im looking to buy and move forward this week so I can install and have it tuned..
Old 07-19-2009, 08:05 PM
Turd Gen Guy
1nasty86's Avatar
id keep the stock aluminum block and go 383
Old 07-19-2009, 08:08 PM
LS1Tech Sponsor
hellbents10's Avatar
I would stick with the 346/7 if you would like to stick with the 67mm turbo and have it all work well. This will also help you save some money by using the stock crank.
Old 07-19-2009, 11:16 PM
OUTLAWZ RACING's Avatar
Hell bent is right. You upgrade to a 402 then you need a bigger turbo and maby a cam and so on. Stay with the 347 build throw 10-15 psi at it and enjoy.
Old 07-19-2009, 11:19 PM
Schantin's Avatar
x3 on the 347. My friend Ricky had this prob last year w/ his ProCharged Camaro. For the $$, rebuilding the stock engine is the most cost effective and can be done with forged internals for about/under $3K. The -67 will work well with this displacement and you can up the boost to 12PSI no probs with good tuning.
Old 07-20-2009, 02:28 AM
SS Ryan's Avatar
oh wow, a little off topic but do you mind tellin me how many lbs of boost you were running when your engine blew?
I just picked up the exact STS kit, and im bone stock
thanks
Old 07-20-2009, 09:09 AM
thanks
Its always a gauntlet on stock motors. Safe tunes and they still can let go 5 psi they still can let go. **** breaks my stock ls6 went at 30k miles and 8 psi on a good tune. I still think a injector lock up but Im not sure #5,8 pistons check out. But it is safe to say the psi from most people run is 8 psi 10 is pushing it. Intercooler is a must and a good fuel system.
Old 07-20-2009, 03:37 PM
SS Ryan's Avatar
Good to know, im planning on running about 6lbs of boost, intercooled, 42lb injectors and racetronix fuel pump with professional tune, i got about 30k miles on my stock LS1 but after hearing that i will be crossin my fingers it holds up.
Old 07-21-2009, 08:17 PM
She will do good I beat the **** out of mine lol!
Old 07-21-2009, 09:06 PM
vipvegas's Avatar
thanks for the stolen thread he's worried about when and if his motor will go....
Im the one sitting with the shot motor now!!!
Old 07-21-2009, 10:12 PM
hawk584's Avatar
Call Garth at Leading Edge Performance
Old 07-21-2009, 10:22 PM
gametech's Avatar
thanks
If you use the stock STS tuning (ie, Nelson), your motor is on borrowed time at 5#'s. If you do a real tune, 10-12 #'s won't be a problem. The ls1 hard parts are extremely overbuilt from the factory. Unfortunately, the most overbuilt parts in the world will still crumble under repeated detonation. Ringlands go first, then the rest of the pistons, then head gaskets, then bearings and rods. At some point in between the plugs melt. A "perfect" tune can take all the other parts to rod or head gasket failure.
Old 07-22-2009, 07:31 AM
SS Ryan's Avatar
Sorry bout the hijack really didn't mean to. Thanks for the info. Good luck with your engine!
Old 07-22-2009, 01:21 PM
omore001's Avatar
Well, I'll be the black sheep and disagree with rebuilding the stock 346. My STS 347 recently gave out on me at 8 lbs with a good tune. After shopping around for a forged rebuild, I made the conclusion that it would be more cost effective (at least in my case) to go with a fully built iron short block from one of the vendors. I picked up a new fully built 370 iron block and some low mileage 317 heads off an '06 truck for just under $3.2K total. I can still make a few hundred bucks off of my 347 aluminum long block. I'm currently in the middle of the swap. If you must have an aluminum block, go 347 or 383. If you want to spend the same amount and have a bigger bore iron block 370 and still have a LS1 block to sell, talk to a vendor. So far, I have no regrets abandoning the aluminum block for the iron block. Regardless of your selection, best of luck to you on your build.
Old 07-22-2009, 01:24 PM
NemeSS's Avatar
vote for forged lq4 with upgraded 317's
Old 07-22-2009, 02:31 PM
longrange4u's Avatar
Having been down this path... I would agree with Hellbent. If you are on a budget of less then $5-10k... I would stay with the 346 forged... drop your compression with pistons to around 9.0 get a good tune... and you will have lots of fun!
Or... end up like me... $50k later... two different setups... three shops... and just now happy with my setup!
Quick Reply: Blew stock 346 with STS need help where to go from here? 383? 402?
